![]() | Home > Puma (Tdci) > Turbo hose worn through - Not the usual. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8396 ![]() ![]() ![]() |
mine is without that insulation so one less worry! Cheers
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4331 ![]() ![]() ![]() |
Which makes me wonder why it is even there in the first place. 2007 110 TDCi Station Wagon XS
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 683 ![]() ![]() ![]() |
It used to be fitted to CSW models along with the plastic fibre under trays to reduce the drive by noise for various overseas regulations involving it the CSW being classed as a car not a utility vehicle.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17936 ![]() ![]() ![]() |
The padding was only present in recent years on the XS, I think, and I seriously doubt that it does anything useful.
Thanks for the heads up ~ another thing to check.
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1125 ![]() ![]() ![]() |
Thanks to your post, Bluest, I had a closer look today, and may just have avoided a hose leak
![]() Now, my 2015 doesn't have the padding anymore, BUT one of the bolts holding the (now plastic) inner wheel arch has ripped a protective sleeve of the turbo hose. Sooner or later, the hose itself would have been damaged, I'm sure (luckily, there is a wire around the hose, which may have protected it). I put some washer on the bolt, so it isn't going in as far as before. But you can also see, the hose is rubbing on the inner wheel arch (easy to see, thanks to all the dirt ![]() Any ideas how to improve this situation welcome. ![]() Click image to enlarge ![]() Click image to enlarge |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
Happens to me some years ago, If I remember well I replace the rivet by a bolt that don't touch the hose.
Cheers! Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
So you mean in my case replace the bolt by a rivet?
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
Mine did exactly this in August. The stock rubber hose gets soft with heat and time and moves over to rub against one of the bolts that holds the air box support.
![]() Click image to enlarge ![]() Click image to enlarge Roaming around 🇳🇴🇨🇭 |
I replaced all of them with BAS silicone hoses which are much more stiff and don’t flex. Soon I’ll add the hose-to-alternator bracket that the rhd cars got. For 95 bucks the BAS hoses were an easy buy for me vs trying to source something else (I was travelling for a month and needed a proper solution, fast) Roaming around 🇳🇴🇨🇭
Can you reverse the direction of the bolt? Or just cut the excess threads off in situ. If you shortened the bolt off the vehicle would you still be able to fit it? As for the hose moving laterally ~ just try-wrap some foam or sleeve with an old section of hose so it acts as a sacrificial rubbing surface. The harder the material, within reason, the better. I've seen old mountain bike tyres used to good effect. |
LR053189 (its actually for RHD cars to keep the hose off steering gear) seems like a good addition. I have ordered one to fit. My BAS hose is not rubbing at the moment, but that hose is so long it does move around a bit. LR057448 & LR053189 Roaming around 🇳🇴🇨🇭 |
Will the LR053189 fit a 2.4? 2007 110 TDCi Station Wagon XS
