![]() | Home > Puma (Tdci) > Puma 2.2 2013 Immobiliser ECU burn |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1125 ![]() ![]() ![]() |
Sorry to hear that. Maybe a short in the rear doors‘ wiring; the flexible part between door and B post?
They‘re directly connected to the ALM/AS10 with no fuses so could burn the ECU. |
AT50HP Member Since: 07 Sep 2020 Location: Centurion Posts: 3 ![]() ![]() ![]() |
Thank you - will afterwards fuse those lines- Appreciate
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 682 ![]() ![]() ![]() |
Are you sure that you need new alarm ECU? First try to remove the current one and look for burnt parts. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
Would be easier to look for unburned parts 🙂
