Home > In Car Electronics > Window DAB antennas
excossack
Window DAB antennas
When I bought the JVC KD-X561DBT I ordered a stick on DAB antenna. Looks to be normally mounted to the windscreen. Could I get away with sticking the DAB antenna to the Alpine window? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #855075 9th Sep 2020 8:11am
jonny
Yep - I've got a stick on spiral type one in my alpine window, works fine.
Because the window is curved the black box part doesn't sit flush against the glass, but it still works fine...
Post #855081 9th Sep 2020 8:31am
excossack
Cheers. Mine has the black plastic DAB with an earth tag and a clear plastic with metal tracks built in that needs sticking to the glass. 1999 Defender TD5 110
Regards
John M0VAZ
Post #855086 9th Sep 2020 8:45am
jonny
Sounds similar to the one I have:
https://www.halfords.com/technology/car-au...38357.html
The black plastic bit is flat so only sticks to the curved window at the edges, but that could be easily cured with double sided sticky foam in the middle, I've just not got round to it yet. I moved it there from the windscreen after having a heated screen fitted and it seems to work just as well...
Post #855130 9th Sep 2020 10:04am
excossack
Cheers. Very similar to mine. 1999 Defender TD5 110
Regards
John M0VAZ
Post #855133 9th Sep 2020 10:16am
excossack
Fitted the DAB antenna to the Alpine window tonight and so far, sat in the drive, the DAB signal is good and the reception is very clear. How this will work while up and down the hills of Wales or up the motorway remains to be tested. 1999 Defender TD5 110
Regards
John M0VAZ
Post #855222 9th Sep 2020 7:07pm
Tr90
United Kingdom 2000 Defender 90 Td5 CSW Alveston Red
I got an adapter that uses the existing wing top aerial. Picks up DAB brilliantly and loses it in the same place as my daily drive
Post #855230 9th Sep 2020 7:56pm
excossack
My existing FM aerial, at best is......well....useless and needs replacing. Sometimes the radio signal is spot on and other times the signal turns to mush,. 1999 Defender TD5 110
Regards
John M0VAZ
Post #855245 9th Sep 2020 9:13pm
AMBxx
I stuck my DAB aerial onto the bulkhead behind the radio. Really crap reception, so best put it somewhere else. Shocked
Post #855282 10th Sep 2020 8:24am
excossack
I wonder why.? Smile 1999 Defender TD5 110
Regards
John M0VAZ
Post #855283 10th Sep 2020 8:39am
AMBxx
I know. Embarassed
In my defence, my wife has just started to use DAB in her car (only took 5 years to try). All we get here in East Yorkshire is the same BBC crap you get on FM plus loads of hits of 80s/90s stations.
Post #855292 10th Sep 2020 9:30am
excossack
I am hoping for when I do my long trips I.e rallies into say your area I can get something other than the crap you get on BBC radio. 1999 Defender TD5 110
Regards
John M0VAZ
Post #855296 10th Sep 2020 9:49am
AMBxx
I just stream from my phone most of the time. Data is cheap now.
If there's no 3/4G connection then chances are there's no DAB either. I reckon DAB will be turned off before FM!
Post #855297 10th Sep 2020 9:54am
excossack
I don't stream but I do normally have a USB pen drive handy with some tunes on. 1999 Defender TD5 110
Regards
John M0VAZ
Post #855298 10th Sep 2020 10:10am
Stacey007
Mine has been on the Alpine window for a while now....
So much so behind the 'sticky' bit is a fly trap for loads of little flies Smile
Post #855307 10th Sep 2020 11:51am
