Home > Technical > Hi Cap, heavy Duty Spec
peterl
1987 Defender 90 300 Tdi HT Epsom Green
Looking at a hi cap on e bay and it says it is a Heavy Duty spec, 3500kg with Heavy duty double springs.
Can anyone explain the double spring option, how they are located and was it an option.
Thanks
Pete
Post #85504 21st Aug 2011 9:48pm
sc70
Wales 2015 Defender 90 Puma 2.2 CSW Santorini Black
i think its an extra smaller spring inside the main spring
Post #85509 21st Aug 2011 10:10pm
Glynparry25
Yep... from what I thought was that it is standard..... what would be the point of a Hi-cap with a low weight carrying ability? Unless you are transporting feathers maybe.
Glyn Dog Sheep
Post #85520 22nd Aug 2011 6:09am
HiCaps didn't have the double springs (AKA 130 springs) as standard, unless you chose the HD option.
If you wore green for a living, the HD option would also include a salisbury front axle!
I've got the 130 springs on the back of my 110 SW. As SC70 says, it's a smaller spring inside the main spring, with a cap on the top (sits under the chassis spring mount) and a bit that bolts onto the lower spring mount, which locate this smaller spring in place, so if you were thinking about it, you couldn't have drop out springs and relocation cones.
Post #85759 23rd Aug 2011 6:31pm
