![]() | Home > Puma (Tdci) > Failure to start in extreme cold |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
mine started no issues in -15 last winter. Maybe there is some treatment added to our diesel at the refinery though to stop it gelling though.
Maybe you need to add something to yours ? Pom |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2475 ![]() ![]() ![]() |
It is not normal at all. Mine has been at -17ºC and no issues. Maybe there is a prob in the lifting pump? Puma 110" SW
I had mine start in the -20 C range, remember that diesel starts to turn I to a more gel like substance before freezing at around the -9 C.
be warned if you start the engine in temperatures below -9 C leave them running for a while or you'll just fill your fuel filter with congealed diesel and you'll then need to replace it ![]() 2011MY 110 XS USW Black |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Untreated diesel will start to gel at -4, and as your in SA then i guess they dont sell winter fuel there. Try adding some 2-stroke oil at a ratio of 300:1 and this should help a little.
Pete. |
It is not related to the engine but to the VERY BAD DIESEL QUALITY.... It is the paraffin (you start the engine,but the paraffin block the filter....) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
