![]() | Home > Td5 > transmission vibration |
As long as you don't go mad, you'll be fine to remove each prop-shaft in turn and, with the diff-lock engaged, be able to drive it on just the one remaining. Darren
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 987 ![]() ![]() ![]() |
Short answer is yes. No problems. As above ☝🏻 Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17913 ![]() ![]() ![]() |
Don't forget that with the rear prop removed you'll have no handbrake unless the centre diff lock is engaged.
Make sure your handbrake drum is tight. If it comes off it can do damage.
If you do the rear propshaft test do it with the handbrake drum on and off. The handbrake drum can cause vibration too. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
It’ll be u joints, just grease the
![]() ![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20939 ![]() ![]() |
I needed a couple of washers on each bolt too on the handbrake drum before the nut as with not having the Prop in place the nut would have hit the non threaded shank of the bolt. So some washers on each bolt solved that issue.
IIRC they are an imperial size, sadly I can’t remember off the top of my head what it is. Personally I would then torque those nuts up exactly the same as if the prop was in place. And as mentioned you need the diff lock engaged to and the handbrake drum in place at all times. Go easy and treat it as a very temporary measure. I think I only went 10 days or so when I did mine, they handle differently too. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
I'm pretty sure you'll find they are 3/8" UNF (which takes a 9/16" AF spanner/socket size). |
jaygti Member Since: 04 Nov 2012 Location: essex Posts: 403 ![]() ![]() ![]() |
Correct. Here’s one one of mine that’s stays in the defender at all times.
![]() Click image to enlarge 2002 td5 90 county hardtop |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
I did the same to try and identify which axle/diff had all the slop in it. Turns out it was both (and probably the centre one to boot)
