![]() | Home > In Car Electronics > ARB wiring using TD5 switches |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2358 ![]() ![]() ![]() |
Which switch blanks do you have? Or which circuit are you looking to use? > 110 XS Double Cab
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2964 ![]() ![]() |
Watching with interest
As a starting point there is some useful information here.
https://www.defender2.net/forum/topic63641.html > 110 XS Double Cab |
Rugratnav Member Since: 30 Sep 2017 Location: The wrong side of the Pennines Posts: 11 ![]() ![]() |
We are using these switches; https://bearmach.com/switch-assembly-air-c...gKCh_D_BwE And we were trying to use the ARB loom; https://cdn.devon4x4.com/techpdf/Product%2...0RDCKA.jpg but unsure how to make it work together. Thanks In Yorkshire, but near enough to the Lancashire border! |
Yes but which space in the dash do you have spare currently blanked off? Behind any blank switches is unused wiring that you can make use of so need to know which circuit you intend to use. > 110 XS Double Cab
