Home > Tdi > windows misting
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
windows misting
i put my heater on for the first time in a while and the screen / side windows misted up and a odd smell started then the engine temp went up , anyone got a idea whats going on Confused
Post #852475 27th Aug 2020 9:28pm
bear100
Sounds like a leak in the heater matrix Shocked
Checked the water level? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #852477 27th Aug 2020 9:30pm
tolley
thanks bear for the fast reply Thumbs Up
Post #852478 27th Aug 2020 9:31pm
Check your intake water ‘duck bill’ valves, there are three they are often clogged up and wet and will draw in wet air and cause this too. Take them out if they aren’t already, clean and replace. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #852485 27th Aug 2020 9:54pm
tolley
thanks steve where abouts are they
Post #852692 28th Aug 2020 6:19pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
This! Once they are blocked it turns the interior into a steamy sauna!
Post #852698 28th Aug 2020 6:37pm
tolley
Thanks just what I'd happening
Post #852700 28th Aug 2020 6:41pm
Locate the fan air intake, open bonnet and follow ducting. Feel underneath and you’ll feel the first one, then the other two are a bit further down just before the foam seal into the fan assembly.
Worth checking the gap there too, the foam should be a nice seal between the two but often there is a gap. Mine had this, can cause leaks and draw in warm engine air. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #852758 28th Aug 2020 9:00pm
Mike c
Not sure if we talking about the same thing, I had a blocked drain in the wing air intake duct, so took off grill, scooped the muck out, and poked my finger through the drain at the bottom, it has a rubber grommet type thing that discharges under the wing. Its something you need to keep a check on yearly, more so if you park under trees.
Post #852769 28th Aug 2020 9:24pm
Yes, same part. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #852791 28th Aug 2020 10:02pm
Mike c
Thumbs Up
Post #852793 28th Aug 2020 10:07pm
