Home > In Car Electronics > JVC KD-X561DBT
excossack
JVC KD-X561DBT
For those that have a KD-X561DBT can you listen to the radio and have the reverse camera on at the same time?
What DAB aerial do you use and which reverse camera do use?
The radio looks a tempting swap to my knackered non DAB/non reverse camera radio 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #852697 28th Aug 2020 6:35pm
explore
United Kingdom 2011 Defender 110 Puma 2.4 DCPU Stornoway Grey
You can switch the camera on at any time, I got a deal with a camera and Ariel included for £180, but i used an Ariel that sticks to the windscreen from Halfords, it all works very well
Post #852800 28th Aug 2020 10:42pm
DarrenJ
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I’ve just fitted this this, it works well and is a nice system. I did purchase the Optimill camera too which is great but that was almost as much as the head unit! My head unit came with a DAB aerial inside the box, although that doesn’t seem to perform that well and I will likely upgrade to the combined FM and DAB aerial in the future.
The only problem I seem to have is the handsfree mic has a lot of background noise so people cannot hear me clearly, I cannot find any settings to adjust so still trying to work out how to rectify.
Darren Darren
Post #852853 29th Aug 2020 9:29am
excossack
Cheers Darren. Is yours fitted to a Puma or TD5? 1999 Defender TD5 110
Regards
John M0VAZ
Post #852967 29th Aug 2020 7:30pm
DarrenJ
2011 Puma.
Simple to fit and much easier space wise due to the shallower depth of the head unit.
Personally I think it does look good with the small screen and better than other offerings with just the scrolling text screens and lots of lights.
The rotary button and it’s push to select is simple and easier to use when ‘bouncing’ along country roads too.
Darren Darren
Post #853039 30th Aug 2020 8:15am
excossack
Cheers. Time to hunt down a decent price. 1999 Defender TD5 110
Regards
John M0VAZ
Post #853150 30th Aug 2020 7:05pm
DarrenJ
Most places were struggling with stock when I got mine a few weeks ago. Ironically Halfrauds was the best price but again no stock, not did MUD UK so unfortunately I had to go to Amazon. Darren
Post #853258 30th Aug 2020 11:14pm
excossack
Ordered Smile along with DAB aerial.
Next, what cameras have people used for the reverse camera and could do with a method of switching between two of them. 1999 Defender TD5 110
Regards
John M0VAZ
Post #854017 3rd Sep 2020 1:55pm
DarrenJ
I got the Optimil that is built into the rear number plate lamp, a nice tidy solution that looks factory fit. Darren
Post #854502 5th Sep 2020 9:39pm
miker
I used the JVC camera and put it into a 3d printed housing mounted above the rear door.
In terms of switching, you can buy composite video switches fairly cheaply, or a double pole 2 position switch will probably do just fine. Composite video is not a fussy signal!
Post #854506 5th Sep 2020 10:07pm
excossack
Reverse camera arrived today. Might have a look later tonight and find a suitable home for it,
First thought was under the number plate lamp (has a spacer between lamp and body work) 1999 Defender TD5 110
Regards
John M0VAZ
Post #855309 10th Sep 2020 12:20pm
siglo
Kuwait 2015 Defender 90 Puma 2.2 SW Corris Grey
Darren
Hi Darren,
Did you ever find a solution for this problem? I am having the same issue and I believe I have found the cause at least in my case. I am using the factory mic with the JVC head unit and for some reason the mic is picking up the vibration in the plastic trim. If I just remove the mic from its base and let it hang by the wire, all the callers confirm that the noise is gone.
I've tried putting some sort of insulation (wire harness tape) between the mic base and the plastic but it did not help. I've also tried to reduce any friction or movement in the plastic steering column shroud and the instrument cluster but it did not help either. I've tried over tightening the instrument cluster lower finisher while pushing it down to hold the shroud. It did help for a while but them people started complaining about the noise again. I've used the voice recorder on the phone to check it out myself and the noise is very bad. I think my last solution is to move the mic to the A pillar.
Post #909199 23rd Jun 2021 9:50pm
