Home > Technical > Puma door glass removal |
ibexman Member Since: 13 Dec 2008 Location: kent Posts: 2882 |
It’s quite easy it’s only door card nuts bolts and screws
27th Aug 2020 10:38am |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 460 |
yep got that far, have you taken one out yourself
27th Aug 2020 10:40am |
with the door card removed
Click image to enlarge have the top window glass one inch up from top rubber seal so you that you hold it in place with clamp or tape and stop it from dropping down Click image to enlarge window winder to window fixing screws loosened so that sliding can be made free from the bottom of the window glass next Click image to enlarge remover window winder inner panel fixing screws and with the two window winder to window fixing screws loosened so you remover winder inner panel also disconnect and remover inner door lock opening lever Click image to enlarge with the window winder inner panel removed you can now remover the glass, at the bottom the hing end window channel you find self tipping screw remover it with now the tricky bit you will need to hold the window at the bottom end with the clamp or tape removed from the top you can work window out from the door frame Last edited by dorsetsmith on 27th Aug 2020 12:07pm. Edited 9 times in total |
27th Aug 2020 10:59am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16947 |
Edit - post deleted because the one above, which it crossed with, says it so much better.
27th Aug 2020 11:00am |
Yes Click image to enlarge removed from old door and fitted in to new drivers door Last edited by dorsetsmith on 27th Aug 2020 12:38pm. Edited 1 time in total |
27th Aug 2020 12:09pm |
Thanks @dorsetsmith, i was being gently trying to twist the glass but will try again moving in the direction in the photo
27th Aug 2020 12:11pm |
Thanks blackwolf |
Polarismd Member Since: 13 Feb 2022 Location: Leicestershire Posts: 61 |
Hi,
Is there any chance someone could add the images back into this post? Thanks in advance. Chris |
19th Dec 2022 11:40am |
