Home > Td5 > Intermittent rear wiper gizmo
Page 3 of 3 <123
Martin
Site Admin
Watch and weep Laughing
Connections-wise, it is as follows:
  • Remove and replace pins from the rear wiper and rear wash switch (this will be plug-and-play eventually)
  • Attach one wire to the loom near the fuse box
Martin  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #852120 26th Aug 2020 12:01pm
Thanks, Martin. Can't view it at work, unfortunately but will take a look later. Darren
Post #852129 26th Aug 2020 12:56pm
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
Mine is 2001 Y reg TD5 90. I fitted a VW 99 relay for the front wipers and the relay I pulled to fit the 99 I swapped with the relay that "feeds" the rear wiper. Both my relays are in the front cab near the gear stick. The rear wiper now runs as the front did when it was set to "intermittent", about every 6 seconds, still a bit quick but better than on all the time. Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #852291 27th Aug 2020 5:53am
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Did that exact same mod several years ago. Though, I could not get the VW relay to work as intended. Regardless this mod is good stuff Thumbs Up 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #852381 27th Aug 2020 2:56pm
Page 3 of 3 <123
