Home > Maintenance & Modifications > Waterproof electrical connectors
Bluest
Are there any waterproof electrical connectors that don’t need special tools to crimp and assemble? I Just need to make 2, 2 pin connections and don’t really want to spend £40 plus on connectors and special crimpers For Econoseal. I have ordinary general purpose ratchet crimpers already, so anything that’s fine with those would be good. 2007 110 TDCi Station Wagon XS
Post #851817 24th Aug 2020 10:57pm
rallysteve
What is it you are connecting and where (i.e. current and environment).
If practical I am happy to crimp cables with Superseal, Econoseal or Deutsch DT and post them?
Cheers Steve 02' 110 TD5 Double Cab Rebuild Thread
Post #851832 25th Aug 2020 7:52am
Bluest
It’s front sidelights. The car side is part of the loom so won’t won’t be able to post it, it thanks for the offer though Thumbs Up 2007 110 TDCi Station Wagon XS
Post #851844 25th Aug 2020 8:50am
rallysteve
No problem Thumbs Up
Do you have a soldering iron? If so, might be more practical to solder on a pre-crimped connector with short lengths of cable and heatshrink?
Cheers,
Post #851848 25th Aug 2020 9:05am
excossack
I crimp my Econseal with a pair of short needle pliers. Rubber seal over the wire, wire into the pin, crimp over one of the little wings, crimp over the 2nd wing, a good squeeze and then crimp over the last two wings that hold the rubber seal. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #851852 25th Aug 2020 9:29am
Bluest
Cheers,
Steve
Thanks, didn't think of that. I could do with a bit of extra length in the loom anyway. 2007 110 TDCi Station Wagon XS
Post #851860 25th Aug 2020 9:59am
Bluest
I was wondering if I could do that as I have done it with other connectors before, but I didn't know what econoseal ones are like. 2007 110 TDCi Station Wagon XS
Post #851862 25th Aug 2020 10:00am
excossack
Looking at here
https://www.polevolt.co.uk/acatalog/2w-Eco...tml#SID=57
the pins look the same. 1999 Defender TD5 110
Regards
John M0VAZ
Post #851864 25th Aug 2020 10:15am
Ianh
Not having the crimp tool to use on a 2 pin super seal connector I used the plier and solder method above. My tip would be Lightly tin the wire and the pin first . Make sure the wire is cut exactly the right length. I.e not too long. Crimp the conductor to the pin using pliers then get the soldering iron real hot and apply to the crimped area only. When tinning the pin and when soldering the conductor to the pin have the pin facing upward and vertical so solder cannot run forward to the front of the pin and use the minimal amount of solder else it will gunk up the pin locking tabs and/ or the pin socket and the male and female pins won’t slot home fully and the connector will not seal correctly.
These are the 2 pin super seal connectors I used for Daytime Running Lights (DRL’s) https://www.amazon.co.uk/Waterproof-Supers...B0755W72K8
Note :I did not buy from this supplier but it does show good pics of the connector and pins
Post #851867 25th Aug 2020 10:30am
cee-b
If I'm worried about waterproof, I just use ordinary crimped or soldered connectors and then coat them in Plasti-Dip.
Post #852193 26th Aug 2020 7:33pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Wouldn't that defeat the purpose of a plug?
For a permanent connection you could just use these
https://www.12voltplanet.co.uk/insulated-b...ellow.html
(not sure about these exactly - I use the glue-lined ones).
Post #852197 26th Aug 2020 7:40pm
Bluest
It is those things that I’m replacing. Needs to be a plug. I’ve ordered a pair of Superseal connectors from 12v Planet 2007 110 TDCi Station Wagon XS
Post #852198 26th Aug 2020 7:41pm
cee-b
OK. There was no mention of it needing to be a plug - just a connector.
Post #852204 26th Aug 2020 7:56pm
