![]() | Home > Technical > What is the front bumper bolt torque setting? |
It's a bumper! close it "just enough" Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
NineCherries Member Since: 10 Aug 2019 Location: Falkirk Posts: 59 ![]() ![]() ![]() |
i hear you, its not the bumper i'm worried about its the recovery points on the same bolt.
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 945 ![]() ![]() ![]() |
In the absence of any manufacturer specific recommendation I would rely on the generic settings for the specific bolt size. Bear in mind these figures vary according to the spec of the bolts you are using. Itβs 45Nm if you are using 8.8 bolts but if you have opted for a higher grade bolt for recovery purposes you will need to increase your torque setting accordingly.
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2698 ![]() ![]() ![]() |
I prefer the Hulk grip, slip, take the skin off my knuckles, swear, throw tool, go indoors for a cup of tea. Works every time....... apparently British Leyland approved ...... ![]() |
I appreciate the responses.
Yeah it's 8.8 grade bolts. 45nm it is then. ππ» I did consider skint knuckle tight but.... π Thanks |
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3656 ![]() ![]() ![]() |
If it is a Friday, the chances are the bumper wouldn't have been tightened by BL ![]() |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2307 ![]() ![]() ![]() |
And probably would have had to weld the brackets back on at PDi........
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17996 ![]() ![]() ![]() |
When I bought my Defender the nuts plates into which bumper bolts screw were both missing, and the bolts, just dropped into the holes, were all that were holding the bumper on.
I've always thought it was the chassis tubes doing all the work and the semi-captive nuts were just an afterthought - they're more of a half nut than full nut and wonder if that makes any difference to the torque loading they will take?
![]() Click image to enlarge ![]() Click image to enlarge |
Yes, it will reduce the max sustainable torque.
After my discovery mentioned above I used standard nylon insert flange nuts, a bit fiddly to get in place (winch bumper and steering guard fitted) and hold while tightening but far from impossible. A better engineered solution than the crappy nut plate in my opinion. |
