![]() | Home > Maintenance & Modifications > Raised breather size help |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781 ![]() ![]() ![]() |
I went a bit more esoteric!
![]() Click image to enlarge Rgds. Chris |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Axle breather threads (upto TD5) are G1/8" (BSPP). Td5 and puma have push fit connections already.
I would replace the standard axle banjo connections (if pre TD5) with right angled elbows. But just use the existing gearbox and transfer box breather tubes and just extend them if you want them higher. Steve 02' 110 TD5 Double Cab Rebuild Thread |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3726 ![]() ![]() ![]() |
Did you win a nugget stuff competition?!! |
Cheers Steve, it’s a Puma so I’m assuming I need hose and some gear to make neat manifold. Any idea on the hose size? |
![]() ![]() Just no willpower! Rgds. Chris |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8337 ![]() ![]() ![]() |
6mm male male pushfits and some pipe, extend whats already there. Cheers
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2361 ![]() ![]() ![]() |
You can buy a tidy manifold for the breather pipe ends in the engine bay on ebay.
Bit of a chew sorting the fuel tank breather out, but all done and plumbed in.
