Home > General & Technical (L663) > Worried about no rear lights visible with the tailgate open?
Page 3 of 4 <1234>
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
UK Regs:-
Restrictions on the obscuration of certain obligatory lamps and reflectors
19. Every vehicle shall be so constructed that at least part of the apparent surface of any–
(a)front and rear position lamp,
(b)front and rear direction indicator, and
(c)rear retro reflector,
which is required by these Regulations to be fitted to a vehicle is visible when the vehicle is viewed from any point directly in front of or behind the lamp or reflector, as appropriate, when every door, tailgate, boot lid, engine cover, cab or other movable part of the vehicle is in a fixed open position. Rgds.
Chris
Post #850363 16th Aug 2020 5:33pm
J77
From the manual
Post #850365 16th Aug 2020 5:46pm
Bluest
This issue is the reason why Mitsubishi shoguns have mostly redundant light clusters on the C pillar and a rather cheap looking cluster let into the lower bumper below the rear door. I think Maybe Disco 1s and Isuzu Troopers had something similar, so other manufacturers of similar vehicles have had to implement workarounds in the past. 2007 110 TDCi Station Wagon XS
Post #850367 16th Aug 2020 5:59pm
Rinse and recycle:
https://www.defender2.net/forum/topic43550...p;start=15
Post #850368 16th Aug 2020 6:29pm
VVS210
I knew I wasn't going gaga so I asked over on the D2 forum & they've confirmed that to overcome this problem with the D1 LR fitted a small red light & a reflector to the edge of the door.
This example is from 1991 so in the 29 years that have elapsed between it rolling off the production line & Tim getting his, LR have not worked this one out!
Post #850510 17th Aug 2020 2:40pm
Tim in Scotland
There was plenty of room on the Disco door to fit the reflector and light. On L663 you would have to remove the warning sticker to fit anything
Off Topic
VVS210 In your photo of the D2 rear door it looks like Pangea Green is the modern Interpretation of what I think was called Vienna Green?
 Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #850513 17th Aug 2020 2:55pm
It is interesting that they did this on the original Discovery (now known as the Discovery I) but did not do it on the Discovery II. I wonder why that was.
My Disco II (pre-face-lift) doesn't even have a handy warning sticker about the obscured rear lights. Pre-face-lift vehicles have the indicators and reversing lights in the bumper and the tail, brake, and fog lights in the pillars which are therefore obscured by the open door. The post-face-lift vehicles had the tail lights moved to the bumper so they were not obscured, and I always understood that this change was done specifically to allow the lights to be seen.
Post #850533 17th Aug 2020 4:07pm
Sorry Blackwolf, that's not quite right. The original DII had indicators and fog lights in the bumper whilst the facelift version had reverse and fog lights. In the latter, the side lights were moved to the top of the cluster, presumably to make them more visible above the spare wheel.
Original:
Facelift:
When the Discovery I was facelifted with the introduction of the 300tdi engine, the side lights and indicators were replicated in the bumper and it was a simple and common mod to turn the bumper side lights into stop/tail ones, giving four brake lights. Darren
Post #850614 17th Aug 2020 10:05pm
Yes, thank you, LRA, I must have been experiencing a senior moment when I wrote that (especially since I have a D2 parked out the back and have often cursed the uselessness of the reversing lights). Thank you for correcting me! Thumbs Up
It is however clearly very traditional for Landrover vehicles to have doors which obscure the rear lights.
Post #850627 17th Aug 2020 10:47pm
I'm not sure that they were, at least within the letter of the law. The DII lights were deliberately moved further up the rear columns so that they'd be visible above the spare wheel when the door is open. I think they improved it when the facelift version was introduced but I'm sure that the original layout complied.
Regardless though, the new Defender does seem like a step backwards in this regard. Darren
Post #850643 18th Aug 2020 8:31am
warren
England 2009 Defender 90 Puma 2.4 HT Santorini Black
Funnily enough, I've just bought this book which arrived today..
https://www.amazon.co.uk/gp/product/B08764...&psc=1
It points out this very issue
Post #851450 22nd Aug 2020 6:13pm
Telemarkskier
Well found! Will dealers be giving everyone a temporary lamp to stick on the door handle. I doubt JLR will do a recall to fix it unless pushed by Government legislation to do so or a class action through the courts for selling defective non compliant products.
Post #851460 22nd Aug 2020 7:55pm
J77
It’s not up to dealers. They didn’t build the car.
The Grenadier from what I’ve seen suffers the same issue.
Post #851469 22nd Aug 2020 8:32pm
Tim in Scotland
It suffers the same on both sides by the look of it as the small section of the split rear door obscures the left hand rear lights too! Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #851473 22nd Aug 2020 8:50pm
It is extremely unlikely that a vehicle which is illegal by design would make it through EWVTA and into production, so I suspect that it is legal even if we cannot presently explain how.
Similarly I have no doubt that by the time the Grenadier enters production it too will have EWVTA and will be legal.
Post #851487 22nd Aug 2020 9:24pm
Page 3 of 4 <1234>
