![]() | Home > Technical > Dab on a roof rack CB aerial?? |
| Tribord Member Since: 20 Apr 2013 Location: France Posts: 220
If you don't want to drill the wing, you can go through the wing top vent cover, either the standard plastic one, or one like I now have, below. You then also have the benefit of an easy route into the engine bay or cockpit without having to hide the cable. Has worked well for me. Click image to enlarge |
| Steve_overland Member Since: 14 Oct 2018 Location: Gaydon Posts: 294
Ah is that a digital aerial....how did you earth it? @steve_overland on Insta.
110 expedition vehicle with pop roof |
It just uses an antenna cable direct to a vhf transceiver installed in the cubby box
Ah ok... it’s a dab mount like this I’m trying to understand?? Or if possible convert a cb aerial to work on dab. @steve_overland on Insta.
| All times are GMT |
