![]() | Home > General & Technical (L663) > Worried about no rear lights visible with the tailgate open? |
| markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2704
On my 90 TD5 Classic I have a strip of reflective red tape on the inside edge of the door frame so that it is visible at night with the door open.
Love the strobe light idea. Always best to be safe than sorry........especially with all these ‘smart’ motorways popping up everywhere..... |
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18038
It's a minor point but remember that a flashing red light is illegal except on a bicycle, although it's hard to believe that even the most obnoxious Policeman would object in an emergency though.
| J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3523
I was thinking about getting something like this from fleabay
| Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753
I looked into the Red retro-tape but there is a problem with it, there isn’t a lot of room unless you stick it over the warning label for rigging the triangle. If you have the spare wheel cover fitted then you could stick the red tape onto that so it is only visible with the door open
Click image to enlarge The strobe LED also has a fixed red setting Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
| VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953
The red LED is a cracking idea
Now I could be having a 'senior moment' but I have a vaque recollection that many years ago my first Discovery, a '92 plate 200Tdi 3 door, had a small red light in the edge of the door so that when the tail lights were hidden behind the spare wheel there was still a red light visible in the dark. Surely with the advance in LED technology it would have been a sensible & easy thing for LR to have put a red light in the edge of the door?! |
Looking at my photo where the triangle is rigged you can still see the rear fog light below the spare, I suppose that you could switch those on but you woukd also be breaking the law on a clear night.........
Not great, is it. I've also just taken a look at The Road Vehicles Lighting Regulations 1989 (as amended) and find the following:
So on the face of this it would appear that it isn't legal. Since I can't really imagine that JLR would have obtained EWVTA for and be selling a vehicle that is illegal, I presume that some EEC legislation has countermanded the RVLR 1989. |
This is from the IVA Tester's manual (this is an extract from the N1 manual, but apart from the Note numbers being different the M1 manual is the same):
And Note 10:
So how did the car pass homologation/type approval? It has also been accepted by the USA’s Dept of Transportation and we all know how much the US Govt hates anything imported and tries to regulate against anything foreign coming into the States . Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
| seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1262
I might be wrong but didn't something similar happen with the discovery 1? Seem to recall the introduction of additional rear lights in the bumper to overcome the same issue? 1984 One-Ten CSW
2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 1990 Defender 200tdi CSW (sold) 1989 Land Rover Ninety (sold) 1998 Discovery 2 (sold) 1995 Discovery 1 (auto) (sold) 1990 Discovery 200tdi (sold) 1987 One Ten CSW turbo diesel (sold) |
| Telemarkskier Member Since: 20 Jul 2020 Location: Wiltshire Posts: 129
6
A vehicle which carries a load or equipment which obscures any obligatory lamp, reflector or rear marking. Either– a) the obligatory lamp, reflector or rear marking shall be transferred to a position on the vehicle, load or equipment where it is not obscured; or b) an additional lamp, reflector or rear marking shall be fitted to the vehicle, load or equipment. All the installation, performance and maintenance requirements relating to obligatory lamps, reflectors or rear markings shall in either case be complied with https://www.legislation.gov.uk/uksi/1989/1796/part/II/made It certainly looks to be unfit for purpose at present as its illegal. If the spare wheel is classed as a load/equipment then an additional lamp has to be fitted, so at present there is no way round it so far as regulations go. JLR have made what could turn out to be an expensive mistake if someone is wiped out from behind having opened the rear door at night to get out the jack out of the load bay + warning triangle etc. Not good at all! |
So the warning triangle covers them for the rule about an alternative light or reflector then, but not for the period between opening the rear door and setting up the triangle! Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
I would have thought that the old Defender in a configuration with a rear door and door-mounted spare would do the same, so perhaps JLR feels it has grandfather rights.
And they never supplied a warning triangle with those ........
