Home > Puma (Tdci) > Foreign object in fuel tank
Bill1919
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Stupidly I did not remove the rubber part of my filler attachment (spout) when filling from a jerry can today and managed to lose it into the fuel tank of my MY2015 110 puma. The offending object is about 4 or 5 inches long so I guess it’s not an immediate problem, but I am concerned it might degrade and do some serious damage. Does anyone have any suggestions on how remove it without having to remove the fuel tank?[/b]
Post #850164 15th Aug 2020 5:57pm
You'll have to drop the tank, remove the sender/pick-up, and fish it out that way I suspect, unless it's lodged in the filler pipe where you might be able to reach it with a grabby tool.
Post #850175 15th Aug 2020 7:00pm
Bill1919
Thanks. I can't see it in the filler pipe but might try disconnecting it when the tank is close to empty to see if I can see it then.
Post #850176 15th Aug 2020 7:07pm
Dinnu
Try to get hold of an endoscope / borescope.. they are cheap from ebay, and connect to your phone/laptop to see inside the tank. I would try to attach the camera (use cable ties not tape) to a thin steel rod that you can easily shape, perhaps with the end bent in a 'hook' shape. Make sure you do not get the 'hook' on the fuel pump/fuel level sender unit. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #850179 15th Aug 2020 7:13pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
https://www.ebay.co.uk/itm/1PC-85cm-long-f...Swq9Rb1oF~
Might be handy having something like this to make a grab for it. Thumbs Up
Post #850184 15th Aug 2020 7:24pm
miker
A good friend of mine did this a couple of years back on his 300tdi.
Much internet research led him to the conclusion that hundreds of people had suffered the same fate over the years to no ill effect.
2 days later, his managed to block the fuel tank outlet and leave him stranded, fortunately only 20 yards from home.
Later that afternoon, we had several fun hours dropping the tank so that we could turn it upside down and shake it out again.
Post #850187 15th Aug 2020 7:38pm
Bill1919
Thanks for the suggestions guys. I think I'll invest in an endoscope/borescope to start. I rather not drop the tank unless I have to.
Post #850188 15th Aug 2020 7:54pm
It really isn't hard and doesn't take long to drop and refit the tank on a 110 (be thankful it's not a 90). You need a special tool to remove the pick-up retaining ring though (not expensive).
Post #850204 15th Aug 2020 8:57pm
Damn, that’s bad luck.
Hope you can get it sorted soon.
Out of interest this rubber piece, is that the tip of the spout?
I’m guessing this is the part not the seal between the spout and fuel can neck.
If so, I’ve got one on the spout I have, I take it I should remove it from the end of the spout then?
You’ve also got to be careful of small caps accidentally getting dropped down there such as fuel additive ones.
Seems impossible, but easily done if not careful with the fuel cap taken off. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #850205 15th Aug 2020 9:06pm
In the good old days Land-Rovers had strainers on the tank filler to prevent this sort of mishap.
Post #850210 15th Aug 2020 9:40pm
Bill1919
Yes the caps of fuel additive bottles I'm always careful with. The rubber part of the spout is similar to this one. Needs to be removed before use.
Post #850212 15th Aug 2020 9:41pm
lonewolf
United Kingdom 2010 Defender 90 Puma 2.4 CSW Zambezi Silver
I bet it’s still in the filler pipe. I bought a flexible claw tool (Rolson) a couple of years ago, end lights up if needed and magnetic, about £12. Have you tried pushing a thin wire down the filler neck/tube to see if you get any resistance?
If it’s detected in the tube the claw would help to get it out.
Also great for scaring grandchildren Twisted Evil
Post #852434 27th Aug 2020 6:40pm
Doesn’t that rubber tip have the mesh pre filter in though or is that in built into the metal part?
The filter being designed to catch any minor debris that may have got in the can. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #852458 27th Aug 2020 8:17pm
Bill1919
The rubber tip that I lost into the tank was just an extension to the filler attachment. Unfortunately, it wasn’t in the filler pipe.
I removed the filler pipe at the tank end so I could get a better look with an endoscope but could not find the offending object. I did see what looks like a seal from a fuel additive bottle however I did not want to poke about to much in case I did some damage or got the scope caught in the pump/sender unit. So it's tank out sometime in the not to distance future.
Two photos taken with the scope – one of what I think is a metal seal from an additive bottle and one the sender unit float on the bottom of a almost empty tank.
Post #852647 28th Aug 2020 3:49pm
Under seat tanks same on extension filler tube ~ perfect for jerrycan without spouts.
Post #852677 28th Aug 2020 5:34pm
