Home > Technical > Odyssey (dead) and CTEK
Steve_overland
United Kingdom 1997 Defender 110 300 Tdi HT Chawton White
Hi there I have two Odyssey pc1500 batteries, during lockdown I have had the vehicle plugged into the mains with a CTEK MXS25 trickle charger and Ctek 250s with smartpass. A week ago I noticed some acid like film on the battery and then today I went for a drive and noticed the fridge had no lights at all until I connected the mains power again. This is the second time this has happened and is obviously an expensive habit Replacing batteries( the start one seems perfectly fine... any advice please folks??? @steve_overland on Insta.
110 expedition vehicle with pop roof
Post #850150 15th Aug 2020 4:11pm
NinetyTD4
Wales 2012 Defender 90 Other SW Keswick Green
Didi you check the correct setting of the chargers? If I remember correct, PC1500 are AGM batteries and not standard lead acid. If you charge with the wrong characteristics and/or without proper temperature sensors, you may cook them. Put a voltmeter for monitoring and check the max voltage at the given ambient temperature does not exceed the manufacturers specs! Never forget: cars have owner, Landrover have field service personnel.
Post #850154 15th Aug 2020 4:22pm
jst
Steve, the odyssey quality has slipped of late in my experience, i think there are now better options out there. i have an odyssey 5years old running an L322 no problem. had two others in defenders that would be 3 years old this year except they were scrapped last year as wouldnt hold charge. they are not a battery i would purchase. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #850180 15th Aug 2020 7:14pm
Steve_overland
It does seem to be that way.... one is fine the other is on charge at the mo so will see what happens. @steve_overland on Insta.
Post #850182 15th Aug 2020 7:20pm
Steve_overland
It would appear that the odyssey is Definitely dead... anyone have any recommendations that would fit in the same spot under the seat next to the other one.... @steve_overland on Insta.
Post #850341 16th Aug 2020 4:10pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
There's only one place worth looking at for battery stuff:
http://www.aandncaravanservices.co.uk/
And remember that Yuasa L36-EFBs are also sold by Halfords as HLB700s, which are much cheaper if you've got a Trade Card.
Post #850373 16th Aug 2020 6:54pm
jst
Tayna.
Cxv27mf numax, 2of them fit in battery box. Sell other odyssey it will pay for both these. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #850376 16th Aug 2020 7:16pm
Tompoole
England 2004 Defender 90 Td5 CSW Java Black
make sure the odyssey isn't receiving a charge of over 15v it will kill it check ctek profile is correct agms need 14.7 to charge to 100% is it wired for agm ?
, are you running a solar panel through ctek or through an independent mppt like a victron? again check profile and set to aGM with equalisation off
I run two oddesy and one optima yellow top on 110 and two yellow tops on 90 without any issues as yet , but voltage never above 14.7v when charging.... Odyssey's run fridge 24/7 on 110. Have fun be happy
Post #850383 16th Aug 2020 7:54pm
Steve_overland
Hi there Ctek was set to normal so 14.7... solar is through the Ctek dual battery and smartpass ... @steve_overland on Insta.
Post #850386 16th Aug 2020 8:12pm
