Home > Puma (Tdci) > 2010 DEFENDER CLUTCH PROBLEM
paulas
came off the motorway last week and clutch pedal went flat to the floor so got a lift home from green flag! checked the mastercylinder and the fluid level is still full. cant see any fluid elsewhere. Any ideas?
Post #849737 13th Aug 2020 1:28pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Could be the slave cylinder on the way out. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #849740 13th Aug 2020 1:35pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Reading this https://www.defender2.net/forum/topic70646...utch+slave might help. Thumbs Up Just because you're offended doesn't mean you're right.
Post #849741 13th Aug 2020 1:43pm
jst
Master or slave failure. If slave may as well do clutch at same time. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #849742 13th Aug 2020 1:47pm
fatboyron
Same thing happened to me it was the slave cylinder that's a gearbox out job while it was out I fitted a new output shaft and a lof clutch
Post #849791 13th Aug 2020 6:10pm
Big Harold
Australia 2015 Defender 130 Puma 2.2 HCPU Alpine White
Yep classic sign of failed slave cylinder.
Mark
Post #849883 13th Aug 2020 10:40pm
dgardel
Italy
Same as mine last year. It was the slave cylinder! yes, that's a gearbox out job while it was out I fitted a new Ford Transit 4x4 clutch Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #849903 14th Aug 2020 9:13am
paulas
Thanks guys. Trying to find someone to do it now. Any idea concerning cost☹️
Post #850379 16th Aug 2020 7:38pm
fatboyron
I just have a look at my receipt mine was just over 1000 with the new LOF clutch new slave cylinder and new output shaft
Post #850382 16th Aug 2020 7:53pm
paulas
Thanks for that mate.
Post #850439 17th Aug 2020 9:03am
