Home > Technical > Quick PUMA maintenance question
CharlieDonuts
France 2008 Defender 90 Puma 2.4 SW Galway Green
How often do you change the brake and clutch fluid ? I last did it two years ago.
Post #849363 11th Aug 2020 8:05pm
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
I think your meant to replace both every 5 years.
Post #849385 11th Aug 2020 10:14pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
Re: Quick PUMA maintenance question
Every 2 years. Rgds.
Chris
Post #849394 11th Aug 2020 11:44pm
CharlieDonuts
Thank you for this. I couldn't seem to find this information anywhere.
Post #849403 12th Aug 2020 5:43am
Mdm
every 2 years is recommended
a lot of modern cars used to be at 3yrs, soit was out of warranty period but almost all the ones we have at work are 2 years now.
Post #849422 12th Aug 2020 7:39am
Dinnu
Would atmospheric conditions play a part? Dot3/4 absorbs water. In low humidity areas, I would guess need less changes than the high humidity areas. Is the vehicle parked outside with lots of dew overnight? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #849436 12th Aug 2020 8:31am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Every 2 years.
Clutch fluid every 2 years, too?
Post #849460 12th Aug 2020 10:37am
Pacha
I do - not a big job TBH. Rgds.
Chris
Post #849463 12th Aug 2020 10:47am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
I had the same discussion with the Indy that looks after the 110 last October after he changed the fluids, the Land rover service sheet had every five years or a certain mileage but he said as the fluid starts to break down as soon as the the container is opened he tests the fluid on every service he does . He now recommends every two years . Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #849470 12th Aug 2020 11:20am
macfrank
For clutch fluid the sheet just says "check/top up" every year / 12k miles (every 2 years for brake fluid).
But if changing it is an easy job, I'll put it on the list Smile
Post #849478 12th Aug 2020 11:47am
jst
i do mine every 2 years or 12k Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #849517 12th Aug 2020 2:03pm
