|  | Home > Maintenance & Modifications > Intermittent Front Wiper- variable delay |
| Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507      |
 And used it in anger today [been drizzly all bloody day] .... what a brilliant mod  Makes a world of difference Guns and Landrovers .... anything else is irrelevant. | ||
|  30th May 2011 8:24pm |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586    |
 But if you push for washing and hold it do 3 strokes.... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition   IID Pro MV License | ||
|  7th Aug 2011 11:26am |
| eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586      | Grazie dgardel, your suggestion worked!     | ||
|  7th Aug 2011 11:36am |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327    | Just wanted to say a big thank you to the collective for this thread   Sounds like an excellent little mod so I've just bought a No.99 relay from eBay for the princely sum of £7.98 inc. postage  Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia | ||
|  7th Aug 2011 12:37pm |
| lam1591 Member Since: 07 Aug 2011 Location: Wiltshire Posts: 15      | I have also just purchased one from Ebay and hopefully it will be here in time for the weekend!  It looks like an ace mod.
 Thanks.  | ||
|  9th Aug 2011 9:33am |
| lam1591 Member Since: 07 Aug 2011 Location: Wiltshire Posts: 15      | Relay has arrived and fitted but wipers run constantly! Possible duff relay?
 Thanks  | ||
|  12th Aug 2011 5:57pm |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327    | Just been out and fitted mine and it works perfectly. Took about ten minutes. For anybody wondering, the relay to replace is the brown one on the right nearest to the heater levers.
 When you say they run constantly, do you mean just in the intermittent position or that you can't turn them off? If the former, then it could just be that the last time it was programmed, it was done so really quickly so that the delay has been effectively set to zero. Try letting them run for a few seconds, turning them off and then turning back on again. This should reset it. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia | ||
|  12th Aug 2011 7:03pm |
| lam1591 Member Since: 07 Aug 2011 Location: Wiltshire Posts: 15      | Hi LandRoverAnorak
 I fitted the relay turned the ignition on and switched the wipers to intermittent and they wipe constantly. If I put the wiper switch back to the off position the wipers still keep going, the only way to stop them is to turn the ignition off.   Thanks | ||
|  12th Aug 2011 7:15pm |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327    | Hmm, doesn't sound good then. You sure it's in the socket the right way around? Darren
|  12th Aug 2011 8:31pm |
| lam1591 Member Since: 07 Aug 2011 Location: Wiltshire Posts: 15      | Hey LandRoverAnorak
 I looked at it and it will only fit one way with the terminals are set up.  | ||
|  12th Aug 2011 8:49pm |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327    | Oh dear. Definitely not good   Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia | ||
|  12th Aug 2011 11:17pm |
| lam1591 Member Since: 07 Aug 2011 Location: Wiltshire Posts: 15      | Hey all,
 Just fitted my new relay and still no good  When I put the old unit in it all works fine. Any ideas? I have been trying vw relay 99 part number 375 955 531 I've tried two now and no luck. | ||
|  17th Aug 2011 5:04pm |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327    | That's exactly the one I'm using without any trouble:
   To be honest, given that they seem to work for others too, I can only think that there's something strange about the wiring in your vehicle. Sorry, can't be much more help than that  Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia | ||
|  17th Aug 2011 7:49pm |
| lam1591 Member Since: 07 Aug 2011 Location: Wiltshire Posts: 15      | Hello LandRoverAnorak,
 How many pins has your relay got? I'm not sure if it makes any difference but my 99 relay is half the size of the one shown in your pic and the part number is stamped into the side not printed. Just wondering if the one I have is a newer version? | ||
|  17th Aug 2011 9:10pm |
| Posting Rules
