![]() | Home > For Sale & Wanted > [Wanted] High/Low/Diff lock lever/mechanism |
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 237 ![]() ![]() ![]() |
Does anyone have a spare lever/turret for the lt230?
I've fitted a td5, r380, and lt230 from a Discovery 2 to my Defender and forgot to retain the high/low and Diff-lock lever housing which bolts to the top of the gearbox. Can anyone help? Thanks! 1990 Defender 110 200TDI Camper - now converted to Td5 power |
Hi, yes just the lever/pivot. I've got the casting that holds the gear stick turret.
A photo would be great, thanks! 1990 Defender 110 200TDI Camper - now converted to Td5 power |
Gasket Member Since: 30 May 2020 Location: Manchester Posts: 632 ![]() |
No worries - I’ll grab the photos this weekend. It’s from an early TD5 defender (R380 suffix K), left over from a 5-speed conversion for a Series IIa.
Hi - is this what you’re after?
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Hi Gasket,
Sorry for the delay, yes that's exactly what I need. How much would you like for it? I'm near Leeds so would probably need it posting if possible? Thanks, Harry 1990 Defender 110 200TDI Camper - now converted to Td5 power |
Spot on. PM sent.
RuiPires Member Since: 12 Jul 2018 Location: Braga Posts: 19 ![]() ![]() ![]() |
Hi, as this topic is still open, I don’t know if you still need the part, so here’s what I have:
I'm all sorted, thanks! 1990 Defender 110 200TDI Camper - now converted to Td5 power
