Home > Maintenance & Modifications > Horn not working...2007 Puma
petercassidy
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Bonatti Grey
MOT on Monday and just found out horn not working.....
I've so far eliminated...
Fuse all good
Switch on stalk (swapped it out with another one)
Horn ( leaving the drivers door open and activating the remote LR fob causes horn to sound as a warning) therefore horn works.
So that leaves a wire break somewhere in the loom.
Where are the obvious wire loom failures or specific points that would still allow the horn to work in conjunction with the LR alarm?
I might just run a wire as a bypass to the loom from the stalk switch to horn as a temp solution.
Thoughts?
Post #848425 6th Aug 2020 8:39pm
jst
Key fob makes horn sound or back up sounder? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #848457 6th Aug 2020 11:12pm
petercassidy
I'm not sure. It's the factory fitted alarm. If a door is open when you click to lock the doors the doors lock but the horn sounds too. Is this a different horn to the normal steering wheel stalk operated horn then?
Post #848460 6th Aug 2020 11:19pm
Dinnu
Dont have 2007 electrical diagrams, but on 2012 electrical diagram I see the horns are connected in a few different ways, I think it depends if you have the anti theft system or not.
Since you mention that you have factory backup alarm, then can you check if you have Relay Sounder Alarm (R200). Seems to me that relay and the Alarm Ecu are used to trigger the horns.
Have you also checked if you have 12V before the horn switch all the time, and 12V after the horn switch when the switch is pressed? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #848471 7th Aug 2020 6:52am
If you don't have a battery backed alarm sounder you have a separate horn for the alarm, and in all the circumstances you describe this is what you're hearing, not the vehicle horns.
There is one vehicle horn adjacent to each headlight and it is likely that both have packed in. To access them remove the headlights (an easy screwdriver-only job). The horns have odd connectors on them but if you're not averse to changing the connectors there are plenty of good aftermarket horns from manufacturers such as Fiamm which can be fitted which are better value than genuine parts.
Post #848474 7th Aug 2020 7:44am
petercassidy
Ah, that's actually encouraging to know that a different horn is used for the alarm.
I'll have a look at the horn behind a headlamp then. Does one horn feed on to the other? Which one is the first horn in the series?
Post #848484 7th Aug 2020 8:31am
G4UJS
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
both of my horns packed up at the same time.... I bought the replacements from Bearmach with the correct connectors for less than £15 for the pair.
easy fit
regards
Rob
Post #848490 7th Aug 2020 9:10am
The horns are connected in parallel, so if one fails the other should still work. It is likely that both have failed, but check the wiring with a meter or test lamp before forking out for new horns.
Usually you don't notice when the first one fails because they not exactly loud even when working, but you do notice when the second fails!
Post #848493 7th Aug 2020 9:19am
petercassidy
That's weird that they both packed up same time??
Post #848494 7th Aug 2020 9:20am
Posts crossed! See my update above.
Post #848495 7th Aug 2020 9:20am
petercassidy
Ok, so this afternoon I removed one horn and attached it to a battery...nothing.
So took a horn out of another vehicle and hey presto, working!
Post #848924 9th Aug 2020 10:03pm
petercassidy
Got 2 OEM replacements today and fitted them. All good now.
Post #850804 18th Aug 2020 10:01pm
Thumbs Up
Post #850818 18th Aug 2020 10:57pm
