Home > Technical > Puma remapped
dgardel
Italy
Puma remapped
For gentelman drivers that have (like me) the Puma re-mapped:
Mine don't smoke except when, expecially over the 2000 rpm, under this condition:
0. I drive up to VI gear
1. I release the throttle
2. Push very soft the throttle up to the engine is just pulling (just a very litte bit) NOW I SEE BLACK SMOKE!!! not so much but I see it. Shocked Shocked Shocked ONLY DURING THIS TRANSIENT
3. Now if I push the throttle for have acceleration (eg WOT 100%) the engine pull hard without smoke......
Could we check???? Thumbs Up
Post #8450 15th Mar 2009 10:09pm
dgardel
Italy
Nobody can check????
For people with "standard" map : can you check it (over 2000 rpm please)???
Post #8477 16th Mar 2009 2:05pm
Grockle
No smoke in std set up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #8479 16th Mar 2009 2:23pm
Eduardo
No smoke with standard setup in any conditions
Regards Eduardo
Post #8480 16th Mar 2009 2:38pm
dgardel
Italy
Bha!
I'll investigate...... Thumbs Up
Thank at all
Post #8482 16th Mar 2009 2:50pm
dgardel
Italy
Found the problem!!!!
we must reduce the "transient map" (it work only when the throttle is moved up) more or less -5%
tomorrow mornig we'll do the job!!!!
later my response.
Post #8497 16th Mar 2009 6:57pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
Hi dgardel
I have a re-mapped puma and no smoke at all. 130 crew cab
98 V8 Disco
Post #8565 18th Mar 2009 6:34am
