![]() | Home > Td5 > Old Nanocom question. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6208 ![]() ![]() ![]() |
I have an old one (pre USB)... I'll whip the lid off tomorrow and take a look
Thanks mine is also serial port.
![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Wow spooky....I just took some pictures in the last 10 minutes
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge No jumper links on mine either |
Thanks very much, so that is not the reason I can not connect my laptop. Roel
Have you got the USB serial driver software installed?
Correct port number set? |
I even have a serial port on my Toughbook CF-18.
I also tried an usb to serial connector and that works with the MSV-2 for the Disco 3 I had. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
I tested my cables and even measured the connection on the Nanocom one. Connector 2,3 and 5 have a connection Hi resistance but not open like the others
I have the same hardware version 2.1. My software version is 1.09. Could that be the problem? Do you now your software version? If I open the Nanocom software on my laptop the screen doesn't fill up just on the bottum it says nancom not connected. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
