Home > Maintenance & Modifications > Mixing Coolants
Greyman110
Mixing Coolants
Would mixing 4-5L of OAT coolant (108 boiling point) over time with factory coolant (137 boiling point) cause the coolant to boil and release through the cap?
Post #847248 31st Jul 2020 3:04pm
sako243
You shouldn't mix different colours of coolant as they can react badly together and start eating things inside the engine (seals, aluminium etc).
So given they can chemically react together then as the temperature rises I can only imagine it'll get worse with temperature so possibly. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #847272 31st Jul 2020 4:45pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
When mixed they can also form a gel when mixed which blocks the cooling system and causes overheating. I learned this the hard way after a not so helpful mechanic topped up my mothers old blue glycol filled disco with red oat.
Post #847306 31st Jul 2020 7:05pm
Greyman110
Think I'll be doing a flush Very Happy
Post #847314 31st Jul 2020 7:33pm
Greyman110
If I drain the coolant and flush with water, can I leave it empty until the new coolant arrives or should I not let the system completely dry out?
I obviously wouldn't be starting the car until it was filled up.
Post #847320 31st Jul 2020 7:50pm
rallysteve
If yours is a TDCi then surely it had OAT coolant in from new anyway?
Post #847339 31st Jul 2020 8:47pm
Greyman110
It is a TDCi but the book mentions Texaco XLC.
I compared the boiling point of the OAT I recently topped up with and the recommended XLC or equivalent which seems to have a higher boiling point.
In the last two years since I've owned it I haven't done a coolant change so I don't know if its ever had anything added or changed previously.
Post #847359 31st Jul 2020 9:31pm
Pacha
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
What colour is the stuff that is currently in the system? Rgds.
Chris
Post #847360 31st Jul 2020 9:35pm
Greyman110
It looks red to me.
Post #847366 31st Jul 2020 9:51pm
