![]() | Home > Technical > Dead battery and locked out |
| 90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2308
Unless the locks are seized / disabled then he simply needs to unlock with the key.......
| steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2076
That’s what I thought
| Chugga90 Member Since: 07 Sep 2014 Location: Bucks Posts: 209 |
Does it have twin tow electrics or 13 pin socket you can put fused 12 volt supply to it for operating the locking?
I’ll go take a look tomorrow 👍
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18040
It is entirely possible and indeed highly likely that the driver's door lock will have seized up, in which case it could be difficult to gain access unless the vehicle can be powered.
It is however possible to connect a booster battery (very carefully) to the starter solenoid (for the +ve) and to a decent earth point (for the -ve) and that should power it enough for the central locking to function. Whether the plip batteries are still any good, and whether the plip is still synchronised after all this time is anyone's guess. If that doesn't work you can "slim jim" the doors disturbingly easily. |
Will give it a go tomorrow 👍
| All times are GMT |
