![]() | Home > Maintenance & Modifications > Fitting a new exhaust....on the drive? |
Easy diy if you have basic tools and ramps make it easier. Ray
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3768 ![]() ![]() ![]() |
Piece of cake. Make sure you’ve got the right gaskets and an angle grinder will be helpful for the stubborn bolts!
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2542 ![]() ![]() ![]() |
Would be nice to see some photos when fitted. Defender 90XS SW
On my 90 td5 it was doable but ther front and rear sections were a bit difficult to get in and over the rear axle. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
Going to give it a go!!
Do i need any jointing paste? 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Mine turned up today too.
Mine will be fitted on the drive, along with a transfer box ![]() |
DEF4 Member Since: 11 Dec 2017 Location: West Sussex Posts: 12 ![]() ![]() |
Def 90 TDCI. Fitted mine on the drive - needed to drop rear anti roll bar to fit rear section. Easy to remove old silencers by cutting through pipes in several places with angle grinder.
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 694 ![]() ![]() ![]() |
Very easy on a 110! I think I just had to remove a mud flap.
I only use paste if tubes go over each other but with a complete new exhaust it should be flanges that are bolted together so no paste needed. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2513 ![]() ![]() |
Removing and fitting the rear exhaust section is made easier by jacking and supporting the chassis on stands. This allows the rear axle to drop creating wiggle room.
Flange sections with gaskets should not need paste, if your exhaust has slip joint sections with clamps then a high temp silicon such as permatex ultra copper RTV silicon [url] https://www.permatex.com/products/gasketin...le=en[url] is so much better than a paste that hardens then breaks up. Plus you don’t need so much clamping force which avoids denting slip joints and aids removal at a later stage if required. Noting this is more of an issue with mild steel pipes with thin walls as opposed the harder stainless steel sections. You can use this high temp silicon on flange joints in addition to gaskets if you want to be 100% certain , especially when connecting to an old flange that has corrosion. Note: you do need to wait a few hours for the silicon to set before starting engine. Last edited by Ianh on 29th Jul 2020 7:00pm. Edited 1 time in total |
Well it’s in
![]() A couple of alignment issue but sorted it out One question, the heat shield around the turbo used a fixing on the heat shield around the old cat now it’s just loose on the bottom is there a solution? 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
Pics? |
