![]() | Home > For Sale & Wanted > [Wanted] 110 Rear Springs purple/brown USW |
| hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2363
Edit: sorry nope mine are green/white > 110 XS Double Cab
| AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711
I should have I'll check tomorrow
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8493
no probs Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
that would be great thank you. Out of interest what rear springs are you running on your 130? and have you still got the inner helper springs? Mine is probably similar weight now, store draw, rear hardtop conversion, camping kit, roof tent. I dont want a lift, std height on 235s is good for what i am after. i believe a 130 would of had the purple/brown from new? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
I weighed my 130 and called Devon 4x4 they advised the best set up. I put Old Man Emu springs and shocks on. I retained the helper springs.
Yes the 130 has Purple Brown as standard + helpers. I have for the rear: 4 x Purple Brown STD 110/130 2 x White Green Green 90 I think For the front: 1 x White Yellow HD NSF 1 x Blue Red HD OSF I also have a full set of take off shocks 2 x rpd501000 2 x rnb501450 130's have feeling's as well you know |
| htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 549
Sorry to piggyback, but what springs are on a 2005 Hicap rear. As mine over 250k on originals
If the powder coating is still on the springs you may still see the painted on colours 130's have feeling's as well you know
colour codes long gone, aberdeenshire road salt atrocious
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6219
Not take off's. but purple/brown....
https://www.defender2.net/forum/topic68103.html |
cheers Jamie, Andrew is sending on a set of purple/browns which should be with me tomorrow/Wed so hopefully all sorted. thank you anyway Cheers
No probs
I've fitted a set of military wolf XD rears to mine. Quote hard but gives a good bit of lift, and when loaded up is a nice ride too |
| Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630
Got a pair of Bowler 110 Rear springs sat in the garage...
Regards Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
Cheers Andrew, spr8ngs arrived today, just waiting on the air helpers and hopefully will fit Friday. Cheers
| All times are GMT |
