![]() | Home > My Defender > G4 Edition 90 |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7930 ![]() ![]() ![]() |
Acquire parts...?
![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10385 ![]() ![]() |
Speed parts. (Or is that ‘less-slow’ parts). QRZ 2e0vpf
Like a turbo... or LS3?
Oh believe me, I have enough ear ache over the LS route.... QRZ 2e0vpf
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11049 ![]() ![]() |
I’ve been acquiring bits, ready for a week of spannering...
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge QRZ 2e0vpf |
Nice bits there GREENI, but what is different with the TB
Hey up Clayton, it’s a Disco t/box, so increases the gearing, making dual carriageway cruising a lot more comfortable. QRZ 2e0vpf
Thanks GREENI, thought it maybe, but still had to check
A few days of spannerng. Having removed the intercooler to replace it with a BAS jobby, i found my rad was a bit worse for wear, though not leaking, there was a large amount of corrosion so a call to a friend who just started a motor factors company, he delivered one in person, same day, on a Saturday!
![]() Click image to enlarge However i dropped the t/box out and replaced it with a 1.2 disco version. ![]() Click image to enlarge It’s also had a few other bits n bobs and is now waiting for replacement tyres. The bushes still need doing, but it now drives better with cruising speed achieved at lower revs = quieter. ![]() Click image to enlarge Looking forward to using it on lanes over autumn/winter. QRZ 2e0vpf Last edited by GREENI on 2nd Sep 2020 10:20am. Edited 1 time in total |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
Good work. I much prefer my 90 since the disco transfer box was fitted.
G-P Member Since: 27 Oct 2019 Location: Cambridge Posts: 16 ![]() ![]() ![]() |
I am planning on getting 1.2 gears next on my TD5, is it best to get a whole box from a disco or put the replacement gears in from Ashcroft? Mine has only done 53k and most Disco’s seem to have done 100k + so little worried about putting in a tired box. Thanks
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
Out of interest, how did you sort the speedo drive out? D2 takes speedo from one of the wheels vs Defender using t/box.
Saw a yellow G4 90 heading south on the M3 at Winchester on 22 August, first time I've actually seen one that colour in the flesh! |
The speedo drive was from the rear output nose (not sure it was a d2 box now..a mate had it for his Wolf 110 but know he's putting in an LS, so it came £free), though a very different 2 pin plug on the box, compared to a 3 pin connector on the 90.., I pulled the plug off the t/box and installed the original one off my 90, though the plastic green square drive was too big for the box's gear...a date with a file sorted that out! It works fine.
At G-P, I'm sure Ashcroft may be able to either supply you with the gears to swap on your own box, or you could send your box to them and ask for the same box back.. Dave is on this forum as 'Ashtrans', best to word him up. QRZ 2e0vpf |
