Home > Maintenance & Modifications > Additional lights - HID or traditional, what configuration
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
Like many others on this site I am thinking about lighting now that the nights are starting to draw in again. I'm planning to have 4 smallish lights across the top of the truck to augment the stabdard TDCi driving lights. I will go for Lightforce lights so that I can use the filters and diffusers. Some questions:
1 - I will probably go for Lightforce 140s x 4 but am not sure whether to go for 4x HID or 4x ordinary bulbs. If the units are all wired with the main beam will the HID strike up time be a nuisance or the reliability of the bulbs be reduced?
2 - I have considered potentially having some or all of the lights running of the main beam switch via a relay - advantages and disadvantages of this
3 - would it be a good idea to have say two units operated on main beam and two on a separate switch - potentially for say Fog or wide pattern use. Would it be a 'waste' to use HID units for this application? (I'm thinking that the HIDs would be better used for long times rather than on-off-on of general high beam use)
4 - I could mount the units to the front of my Hannibal rack - would this present any particular problems or are there advantages in using a light mounting bar? I will probably not remove my rack but should I wish to what would be the best way to incorporate a good quality breakable electrical connection?
5 - I think I've read somewhere that there will be reflections from the lights on the bonnet - other than putting matt paint on the bonnet or using chequer-plate are there any other ideas to reduce this? I was thinking of some kind of shroud or hood to go on the lights
6 - I don't fancy putting lights on the bumper (and I don't want to fit a light bar down there) because of the potential for damage - but should I seriously consider this before I put lights up high?
7 - and finally - LED light strips - seem to be expensive, throw plenty of light, are low power, but not a real beam - thoughts?
Your thoughts and tips gratefully received
Post #84535 15th Aug 2011 6:32pm
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Personally I chose Hella Compact Metal Xenon (expensive but I got a very good deal) and I absolutely couldn't recommend the Xenon enough. I chose to wire them to come on with the Main Beams, I since learned that flashing HID or Xenon reduces bulb life, so I avoid flashing and use hand signals wherever possible! (once the lights have warmed up it is okay to flash with them) You will need to include a switch to isolate the lamps from the standard main beams to be legal, you can get the appropriate switch online or from LR parts. Once you add the additional lights you'll really notice if you switch them off again!! Mounting the lights high (on your Hanibal will mean that any wide beam lights will reflect off your bonnet if aligned low, so consider possibly getting a vinyl cover for the raised bit of your TDCI bonnet ( for example that fitted to the SVX with the 60th effect) you could just get a big matt black sheet and cut it to size!! I chose to mount the lights on a genuine LR a-bar, which I am pleased with, Personally I'd pursue having the lights lower if possible.
Sorry, can't advise on LED's!! have a look at Twisted Performance for potential ideas!!!
Thanks Alex 110 Tdci Double Cab
Post #84579 15th Aug 2011 9:07pm
TJ101
Ditto, what Alex said Thumbs Up
 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #84601 15th Aug 2011 10:51pm
ay4alex
TJ, I made some spacers to put the lights lower on the A frame, I'll take some photos tomorrow, it just drops them into line with the existing Headlights. It just seemed to neaten everything up!
IMG_0137 by .:alx:., on Flickr
IMG_0125 by .:alx:., on Flickr 110 Tdci Double Cab
Post #84602 15th Aug 2011 10:54pm
Lukey Boy
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Steve,
Think I read on a previous post, someone had Lightforce 140s on a roof bar or rack but they wished they'd gone for 170's. It was quite a long time ago though! Confused I wonder if they might look too big? Certainly a higher output though. Thumbs Up 2008 110 XS CSW Stornoway Grey
Post #84611 16th Aug 2011 1:08am
Glynparry25
Lukey Boy wrote:
Steve,
Thumbs Up go for the 170s. They are both mounted on the same backing so overall height difference is only 15mm..... Not noticeable- but the bottom of the light will fill the gap better.
For an A-Bar the 140s would work good.
I am sure Mal will agree with me that the 240XGTs are just out of this world and you can 'flash' them all you like:
When funds permit I will be fitting 4x 170s to my cage with the lightforce lowering brackets so will sit lower then the 140s on standard brackets.
Reflection answer other than the vinyl patch on your bonnet will be a lower lip on your lights so it can't shine in a downward direction. I have a square of vinyl ready to fit- cost about �5
Glyn Dog :sheep:
Post #84616 16th Aug 2011 4:58am
MK
Have 240s http://www.defender2.net/forum/topic2932.h...ious+spots
Normal lightforce bulbs are just great. Personally I would not spent buckets of cash for HID unless you use them everynight. Puma 110" SW
Post #84653 16th Aug 2011 10:48am
SteveS
Thanks for the inputs so far. Anyone got experience with LEDs particularly with respect to beam pattern/coverage?
Post #84768 16th Aug 2011 9:57pm
K9F
Glynparry25 wrote:
I am sure Mal will agree with me that the 240XGTs are just out of this world and you can 'flash' them all you like: Glyn Dog Sheep
Yep! Thumbs Up
Brackets I made to fix the lights to OEM soft A-Bar.
Agree 100% with what MK states: The 240's depicted above in HID configuration were �700 MORE in price per pair![quote] If you go through life with your head in the sand....all people will see is an ar5e!!
Post #84773 16th Aug 2011 10:43pm
SteveS
I'm still looking for anyone with views/comments on LED light bar - coverage, beam pattern etc???
Also if I were to mount lights in front of the radiator (I have air-con fitted) has anyone noticed any discernable difference in cooling/engine temperatures - particularly in hot climes?
Post #85130 18th Aug 2011 11:23pm
Glynparry25
LED lightbars- only used military ones in Afghan, and the light is very clean. It doesn't really have a 'pattern' I wouldn't say it is worth the extra cost. I know one of the German forum members has one on his 110 (has the rock slides with the holes, and twin tube snorkel- maybe he could shed some light on 'civy' application
I have aircon on mine, running the TJM bumper, and the 240 here in Cyprus. Weather is currently 32- 35 DegC and I have spent 1.5 fuel tank loads on and off road and had no cooling issues whatsoever- even when doing long inclines in low range diff lock in so only moving about 2-5mph..... The needle doesn't even move a mm.
Glyn Dog Sheep
Post #85146 19th Aug 2011 7:40am
T1G UP
is it true that LED lights don't attrack insects like normal lights?
if so a full set of LED lights would be an advantage when out in the midges!
Post #85266 19th Aug 2011 7:26pm
SteveS
I've been checking out LED bars from Rigid Industries, looking at various videos people have taken - they look pretty impressive. But are crazy price. However, plenty of advantages as far as I can see including vibration resistance, white light but no HID-type strike up time (can flash all I want), very low current draw considering the light output, longevity, etc.
For the future they seem to be the way to go and prices are bound to come down (particularly with respect to an all HID set-up price)
There are plenty of videos about - check them out for yourselves
Thoughts anyone?
Post #85821 23rd Aug 2011 11:52pm
another option would be to buy Lightforce 140s x 4 and buy a couple of HID kits and swap the bulbs over. HID kits can be bought for about �30 from eblag - (or maybe have 2 filament and 2 hid) just a thought
Post #85835 24th Aug 2011 7:26am
Just a heads up I'm having continual failures with the HIDs on the roof its been suggested that the vibrations from the defender wont be too sympathetic to the HID set up news to me but im at a loss
Im going back to Lightforce 170's they have survived loads of overland trips in the past Thumbs Up
Post #85841 24th Aug 2011 8:10am
