Home > Maintenance & Modifications > How to remove corroded door lock cylinder |
JOHNT01670 Member Since: 24 Jun 2015 Location: CRAMLINGTON, Northumberland Posts: 185 |
I revived my drivers door lock recently having purchased a replacement in error (2 rear door locks)....
I removed the rod from the top of the lock (in your last photograph) mechanism and the cir-clip on the barrel. With the key in place the lock came out without removing the handle - I may have tapped it from inside the door to help the process. The lock mechanism was put into my vice and sprayed with WD, heated up and wire brushed. The parts of the lock required spraying and light help to start freeing them up but eventually all were fully released. I coated them with graphite powder and re-installed and working better than ever. 2006 TD5 2002 Honda Transalp 650 1995 Yamaha Vmax 1200 2014 Nissan Juke (wifes) |
25th Apr 2020 11:37am |
Gasher Member Since: 19 Apr 2020 Location: E Sussxe Posts: 12 |
John
Many thanks for your reply. I'm not sure why but when I put my key in the lock I can't 'feel' anything at all so I wonder if the lock tumblers are frozen in place. Anyway i've tried exactly what you describe but cannot get the lock barrel to come out even with a little encouragement. In fact all I get when I give the inside of the lock barrel a little tap is that the ket fly's out of the lock but the lock barrel stays unmoved. I have even tried to see if there is a small vertical pin on the end of the lock barrel that I need to press down to allow the lock barrel to come out but cannot seem to find one to press down. Ot thats frozen/stuck as well. Did you have to press a pin down? If you did then I'll keep trying. Any suggestion gratefully received Thanks Gasher |
27th Apr 2020 5:08pm |
Hi there,
There should be a release point to remove the tumblers from the barrell but I did not use that as all I wanted to do was free them up as they were seized. That's was how some heat and WD with wire brush and gentle persuasion worked for me. I know my rear lock was also bad and I drilled the tumblers out as that was solid, the replacement lick then went straight in after cleaning. 2006 TD5 2002 Honda Transalp 650 1995 Yamaha Vmax 1200 2014 Nissan Juke (wifes) |
27th Apr 2020 5:54pm |
Thanks
As the space is so tight im going to have to cut the head off the handle bolt nearest the latch to get the handle off the door (the bolt just turns) Hopefully then I can get the lock out and free the tumblers up Fingers crossed |
3rd May 2020 10:26am |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2164 |
Exactly same drivers door issues. Stuck solid.
How did the above pan out Knasher ? Keith |
22nd Jul 2020 10:11pm |
hi
well it turned out to be a bit of a saga but I didi fix it so all fine now I've just typed up what I did which will hopefully assist you Please forgive me if Ive stated what you already know. Im not sure how to attached a pdf to this post I have taken screen shots of each page and attached those. finger crossed. If you have any questions please just ask and Id be happy to help cheers |
23rd Jul 2020 5:00pm |
hi
well it turned out to be a bit of a saga but I didi fix it so all fine now I've just typed up what I did which will hopefully assist you Please forgive me if Ive stated what you already know. Im not sure how to attached a pdf to this post I have taken screen shots of each page and attached those. finger crossed. If you have any questions please just ask and Id be happy to help cheers Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
23rd Jul 2020 5:01pm |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
Unbelievable, I went through exactly the same saga two days ago !
I replaced the door handles along with the locks . The handles torx screws were spinning but I used mole grips to hold it , then drilled it out . I had the second handle off in half the time. I didn’t even bother trying to remove the barrels from the handles as they were seized solid. https://www.instagram.com/hustynminepark/ |
23rd Jul 2020 9:06pm |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 862 |
As another security layer I replaced my entire handle with one without a lock.
Central locking works fine and if it fails i can still get in the rear door. |
23rd Jul 2020 11:39pm |
Great write up Gnasher. 👍
Keith |
11th Sep 2020 1:26pm |
