Home > Maintenance & Modifications > A couple of ARB questions
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Following the fitting of my new tank, I’ve got to put the rear ARB back on, are the bolts that hold the brackets to the chassis ok to be replaced with stainless bolts or are they not likely to be strong enough and stick with some standard 8.8 or 10.8 zinc plated?
On the subject of ARBs, I’ve been given a front bar by a friend and thought I might stick it on to see if the old girl handles any better than just with the rear, but my 300 hasn’t currently got a front ARB fitted and as such is missing the chassis brackets. I’ve seen plenty of weld on brackets But came across some bolt on brackets,
http://www.extreme4x4.co.uk/Store/Suspensi...ixing-kits
which seem easier to fit than cranking up the old welder. So the next question is any thoughts on these? Is bolting the brackets on going to be strong enough in the long run or is it best to weld them on and forget about it?
Post #844742 19th Jul 2020 5:10pm
Co1
Those bolts are something like 38Nm, so no issue using SS.
Post #844743 19th Jul 2020 5:18pm
If you do use SS be careful they don't seize in such a wet environment.
I like SS in its place. But if it was me I wouldn't use them in those locations. Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #844746 19th Jul 2020 5:37pm
There's no reason why stainless fixing should seize in that application. It's when you mix them with ali that problems can occur. Darren
Post #844755 19th Jul 2020 7:43pm
BuckBlu110
They would have a fair covering in dinitrol anyway, but for the bolts that go into rivnuts for the front brackets, i think I would either cover the threads in anti seize compound and or use zinc plated bolts to be on the safe side.
Post #845197 22nd Jul 2020 7:59am
