Home > Maintenance & Modifications > Oil leak on rear wheel.
Grenadier
Knowledgable folk, where is this oil from do you think? What should I check for first?
 Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #844663 19th Jul 2020 8:13am
htb2
Wales
from the drive member paper gaskets or from the big nut at the end, check axle breather is not blocked either.
Post #844670 19th Jul 2020 8:31am
Grenadier
Thanks HTB. It’s certainly emanating from the big nut. I can take it off, check the seal and re-tighten it, but should there be that much oil behind the nut in the first place? Monsieur Le Grenadier
Post #844672 19th Jul 2020 8:36am
williamthedog
Oil seal has gone in axle to give you that much oil, and as said above the paper drive member gasket also. Some people leave the oil seal leak as it lubes the bearings.
Post #844676 19th Jul 2020 9:03am
