Home > Maintenance & Modifications > Air con grill on non air con Puma..
NickMSM
United Kingdom 2008 Defender 90 Puma 2.4 HT Stornoway Grey
I am thinking about changing by KBX set up for the Heritage/Twisted look. However I don't like how the new grill would sit flush on a non air con truck. Is it possible/simple to fit the air con surround grill?
This is the grill - https://www.ebay.co.uk/itm/Land-Rover-Defe...3515854343
Cheers.
Post #840432 29th Jun 2020 12:00pm
Yes, although you'd have to also source and fit the lower fixing points for the grill surround. Darren
Post #840443 29th Jun 2020 1:05pm
Shroppy
United Kingdom 1986 Defender 130 V8 Petrol HCPU Aintree Green
As above, easily fitted to non-aircon models you make up two(?) simple brackets (I've used a bit of ally plate in the past) if you don't want to buy the specific bits. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #840461 29th Jun 2020 2:34pm
NickMSM
Great, sounds fairly simple then - cheers!
Post #840650 30th Jun 2020 10:53am
mk1collector
It’s really simple, I’ve just fitted air con to my td5 and it’s just two bits of kinked flat bar with holes at either end for to screw it in place then your normal four screws on the slam panel at the top. Ray
My build thread
Post #840655 30th Jun 2020 11:09am
Shroppy
Changing the topic of thread slightly, did you use an aftermarket kit or genuine take off to fit air con? 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #840658 30th Jun 2020 11:25am
mk1collector
If that question was for me ^^^ I’ve been buying up genuine bits when I’ve seen them up for sale for the last couple of years and while my front wings were being replaced (due to someone running into me) I figured I’d get the last bits together and fit it all while the front end was apart. So it’s the normal factory set up basically, there’s a few pics in my build thread and I can add some more if there’s anything you want to see Thumbs Up Ray
My build thread
Post #840663 30th Jun 2020 11:44am
mk1collector
Pic of one of the brackets on inside of the grille when I was test fitting it.
 Ray
My build thread
Post #840668 30th Jun 2020 11:55am
Adammacky
Is there a part number or anyone got a link to the actual brackets needed?
Post #843689 14th Jul 2020 5:03pm
mk1collector
Aftermarket stainless steel versions that are about a third of the price of genuine Thumbs Up
https://www.ebay.co.uk/itm/324196462118 Ray
My build thread
Post #843693 14th Jul 2020 5:26pm
Adammacky
Awesome cheers Thumbs Up
Post #843697 14th Jul 2020 5:34pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Has anyone fitted an aftermarket one? Interested to know if the quality is acceptable or not.
Post #843709 14th Jul 2020 6:02pm
Shroppy
Presume you mean aftermarket air-con grilles? I have one in the loft, not fitted yet but, it seems very well made. 1985 127 V8 Build Thread
Series 2 109"
Series 1 80"
Post #843732 14th Jul 2020 7:02pm
LandymanStefan
Yes aftermarket air con surround
Post #843735 14th Jul 2020 7:07pm
NickMSM
Thank you, going to make a start on this soon as I source a grille!
Post #847655 2nd Aug 2020 5:35pm
