Home > Maintenance & Modifications > Roof Light Bar - any recommendations
Page 1 of 3 123>
Kez
Isle Of Man
Having sold my roof rack I now intend to buy a roof light bar and similar lights to the ones just solld- the lights are the easy bit, my problem is knowing what bar to buy. Like anyone else I can do a search on the net or eBay, but usually its hard to know why one that costs £50.00 looks about the same as one that costs £150.00!
I don't want to be suckered just because its being sold by some big company, but nor do I want to end up with a bit of rubbish that looks good in photos but is poorly made or hard to fit!
So any informed advice most welcome Sad
Post #84371 14th Aug 2011 6:42pm
pom
im interested in this as well, with the winter approaching needs some extra lumens for winching the postie out the snow again Very Happy
Pom
Post #84377 14th Aug 2011 7:46pm
Landyrob
United Kingdom 2012 Defender 110 Puma 2.2 HT Alpine White
i bought this last week from First Four. Defender SHADOW Light Bar with Halogen Driving Lights (Clamp-Fitting)
http://www.firstfour.co.uk/light-bars/defe...07458-.php
i see John Craddock have one also with (Clamp-Fitting)
http://www.johncraddockltd.co.uk/products/...t_bar_.php
both have the same advantage NO DRILLING TO THE BODYWORK, IT IS CLAMPED TO THE GUTTER LANDROVER Defender Best 4 x 4 x Far
Defender TD4 90 Hardtop 2.4
Defender TD4 110 Hardtop 2.2
Post #84384 14th Aug 2011 8:40pm
Kez
Isle Of Man
Ta Rob, really appreciate that , and I like the idea of clamp fitting but the logo sure puts me off the first and the second one look odd due to the curve on end - would just look wrong against a straight defender roof. To be honest neither looks that substantial Neutral
Post #84405 14th Aug 2011 10:01pm
leeds
Kez, I have been offered light bars for as little as £20.
Quality can vary a whole lot.
On our red 110, we have a purpose built light bar with 4 lights and 2 aerials on. This is a double bar with brackets being 6mm plate welded between the two bars. Strong ( I can sit on bar without it bending Laughing ) Not a cheap option however!
Cheap eBay ones need repainting within 6 months and lights bounce.
Have you considered the Ali Rhino Rack bars from Oz? H section so you can mount as many lights as you like on top or below the bar. Available black or silver.
Brendan
Post #84413 14th Aug 2011 11:11pm
Kez
Isle Of Man
Hi Brendan, thanks for that, assume you mean this:
http://www.rhinorack.com.au/AccSubCategory..._1_24.aspx
Bit too much like a full roof rack with the facility to add lights, really looking at something specific just for lights- and UK sourced if poss Shocked
Post #84440 15th Aug 2011 8:57am
leeds
No Kez I mean the 'H' section type roof bars as shown HERE
We normally stock them in black. We have 3 on the red 110 with the Foxwing attached to them and a demo rooftent on. If you are going to Peterborough you can have a good look at them so that you can make your own mind up. Also you will be able to see our light bar that we had custom built for our vehicle.
If you like I will take some photos for you and post them up.
Brendan
Post #84529 15th Aug 2011 5:54pm
Kez
Isle Of Man
Must be looking at wrong item as it says it uses a vehicle fixing system and looks like it clips into a car type roof fixing - will send you a email via your website, perhaps you could send me a pic of yours?
Post #84534 15th Aug 2011 6:29pm
jerseyman
Kez wrote:
Ta Rob, really appreciate that , and I like the idea of clamp fitting but the logo sure puts me off the first|
Yes why do manufactureres do that? There are quite a few bits and pieces I would have bought otherwise, For example I fancied some spiffy door sills from a supplier, but in the end decided against it because I drive a Landrover, not an Entreq.
Post #84563 15th Aug 2011 7:53pm
leeds
Hi Kez, some photos for you as promised.
The Australian Rhino Rack Bars are H section.
OK have put this Lightforce light on for illustration purpose. Had to replace the normal 10mm bolt with an 8mm bolt so that I could use the electricans conduit type nut.
Yes you can fix items on the underside of the bars as well
No fixed number of lights or position with these bars
My twin bar light bar
Showing the way the two bars are fitted to both gutter and A post
Showing how the lights/aerials are fitted between the two bars
A good strong light bar
HTH
Brendan
Post #84739 16th Aug 2011 8:13pm
Kez
Isle Of Man
Cheers Brendan, looks great, as luck with have it I think I have it sorted, local independent land rover guy has a bar he ordered in for a customer who never came back, so he's said I can have it at cost so going to see it later. Must admit I think the Australian system looks good, like the fact you can adapt it.
Regards
Kez
Post #84781 17th Aug 2011 7:55am
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
thanks the advice. decision time between the thule, rhino and the first four. BM52
Post #84913 17th Aug 2011 8:56pm
leeds
BM, consider seriously your needs, wants and budget. Not those of any salesman. Razz
You can get a lightbar and lights from £50-60 up to several hundreds of £s
One thing to consider is whether to wire any roof lights via the main beam switch or not.
If wired through main beam switch they will be road legal assuming lights/bulbs are E marked
Wired completely separate from normal light circuits they will be illegal for road use. However that has an advantage when/if anything goes wrong with the main light circuit i.e.main light stalk burns out in that you will still have working lights!
Brendan
Post #84922 17th Aug 2011 9:25pm
bm52
Brendan, thanks for the advice, just been looking around.
i'm not going to add any roof lights. the bars will be used for carrying the occaisional wood planks, posts etc. the bars won't be on permanently.
at the moment i am thinking from here:
http://www.rhinoroofracks.com/land-rover/d...at_99.html
but only if they can deliver by this weekend? otherwise i might just go to LR Dealer and see if they have any in stock and try and get a discount. looks like any local people will only 'special order' thule, so they are out Crying or Very sad BM52
Post #84930 17th Aug 2011 9:39pm
JSG
I don't believe they will be legal - IIRC lights ocer a certain height behind the front axle are not road legal. That is why the Tombraiders were all supplied with the relay missing to stop the lights being used as supplied. They were wired to come on with the main beam via a seperate column switch. John
2011 Tdci 110 CSW XS
Post #84931 17th Aug 2011 9:41pm
Page 1 of 3 123>
