Home > Maintenance & Modifications > How to rear door hinges defender help
LANDROVER
Big Cry How do you remove the rear door hinges on a double cab?
The plate for the bottom hinge is hidden.
The top has a little access hole. ...
As per everything I touch it's turned into a nightmare.
Post #841934 5th Jul 2020 4:33pm
mk1collector
Under the wheel arch, there’s a plastic shield on the rear panel and it’s behind that. Ray
My build thread
Post #841955 5th Jul 2020 6:54pm
Go up the B post from under the car.
Post #841958 5th Jul 2020 7:01pm
LANDROVER
Cheers!
Post #842048 6th Jul 2020 9:52am
LANDROVER
Cheers!
I can see it now! I'd had enough after trying to do the front to discover someone had re tapped the original door mirrors to fit a bodge extension so had to refit the old ones!
Then I managed to mark the new painted hinges Big Cry
I had such a headache by this point I couldn't work out where the bottom plate was on the rear doors Embarassed
I will have to get this done ASAP as it's marking the doors on the bottom and the catch plate badly now.
Post #842049 6th Jul 2020 9:53am
mk1collector
Sorry I was thinking tailgate hinges Embarassed Ray
My build thread
Post #842054 6th Jul 2020 10:09am
