Home > Maintenance & Modifications > Penman
Page 2 of 6 <123456>
seriesonenut
Hi that's a very good idea.
I will experiment and send a photo.................. 1984 One-Ten CSW
2010 XS USW (sold)
1957 Series One 88 diesel
1958 Series One 88 4x2
Post #841301 2nd Jul 2020 3:00pm
JimmyP
Penman brake pads
Do any of you Penam owners know what brake pads are fitted to the Penman lightweight trailer? I’m doing an expedition conversion on one but having real trouble tracking down where to get pads from. Any help would be greatly appreciated. Cheers Jim
Post #841475 3rd Jul 2020 12:08pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Arent the pads the same as those on the rear of the Ford Scorpio? Or was that the MK3 sankey? 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #841523 3rd Jul 2020 2:23pm
Rosco
Are these the ones you need?
https://www.lrseries.com/Military/Sankey-T...EW-GENUINE 2007 - Stornoway Grey 90 XS SW - Gone
Post #841525 3rd Jul 2020 2:25pm
JimmyP
Hi Rosco many thanks for your reply. I’m not sure if the Sankey used the same pads as Penman. I’ll take the old set out and compare them to the pic in the link you sent. I’ll report back. Strangely for such a widely used trailer I’ve not been able to find any guidance at all on t’internet
Post #841551 3rd Jul 2020 4:45pm
seriesonenut
blackwolf wrote:
I don't think you'll have any problems at all with that configuration, but an alternative you could consider is simply to turn the slider plate the other way up. For a Penman the pintle will be free to rotate anyway, so you wouldn't even need to unbolt it and turn it over, and flipping the slider will raise the pintle by at least 2".
Before you throw your hands in the air and decide that I have gone barmy (after all the slider is clearly marked "top" at the top suggesting that it must be used one particular way up), this suggestion was actually made to me by the boffins a Dixon Bate back in the day when DB not only had boffins but were actually knowledgeable and helpful, ie before the last take-over (after which they have raised unhelpful uselessness to an art form).
I wouldn't want to use the slider upside-down for a heavy trailer or one with an exceptionally high nose-weight, but a Penman or Sankey is a puny trailer by trailer standards and the coupling loadings are not large.
Had a look and the slider is different. 4 holes at the top to bolt through the crossmember and two at the bottom for the chassis legs. Could be adapted by welding a plate at the bottom position for the extra holes then reverse (if you follow me). If I decide to get one I might try it 'as is' first. 1984 One-Ten CSW
2010 XS USW (sold)
Post #841555 3rd Jul 2020 5:12pm
By slider I mean the bit to which the NATO pintle is bolted, not the bit bolted to the chassis.
Pull the pin to release the NATO pintle from the vehicle, invert the pintle, re-pin to vehicle, release the rotation lock on the pintle (which will now be at the top), rotate the pintle through 180 degrees, hitch up the trailer, and Bob will become your uncle.
Post #841590 3rd Jul 2020 6:59pm
seriesonenut
Blackwolf how did you know Bob was my uncle?
As fitted
nato h2 by Richard Holmes, on Flickr
Reversed
nato h1 by Richard Holmes, on Flickr
Perfect! That's a great tip..............now for a trailer......... 1984 One-Ten CSW
2010 XS USW (sold)
Post #841604 3rd Jul 2020 7:59pm
You can always benefit from a couple more inches!
Post #841614 3rd Jul 2020 8:37pm
Ianh
Hi all, a couple of questions that I just know you have the answers to Very Happy
Pintile arrangement.
Seriesonenut , after following Blackwolf’s suggestion re inverting the slider and then rotating pintile 180 degrees were you able to couple the trailer with the spare wheel on, or did it require spare wheel removal ?
I’ve ordered one of these. https://foundry4x4.co.uk/index.php?route=p...uct_id=352 .
Designed for mounting larger diameter wheel/ tyre combinations it raises the wheel by 2 inches so hopefully will mitigate raising the pintile hight and may help those with pintiles directly connected to the crossmember who also have a rear mounted wheel. Will reduce view through rear screen but that’s minimal already. Once fitted I will post my findings.
Rewiring to add 12n plug and 12v bulbs.
I’m about to purchase a penman. Will collect with 6ft lightboard. However I will be changing the bulbs on the penman to 12v and add an additional cable and 12n 7 pin plug to existing 12way nato cable and plug arrangement. Tapping in to connector box under the trailer so I can avoid having the lightboard fitted for subsequent use. Any tips on this appreciated. Also are you able to just remove the 24v bulbs and replace with std 12v bulbs. Or are new bulb holders required.
Number plate.
Now this is a dumb question. But where is best to mount the number plate ? I can see the rear off side is where the military number plate fits but a standard legal square one looks too big to fit there and will get in the way of the rear tailgate opening. If you fit so it avoids the tailgate issue it looks like it will protrude beyond the edge of the trailer side ! So wondered what you guys do..
Thanks in advance for any help
Post #861935 16th Oct 2020 4:47pm
seriesonenut
Hi Ianh, no trailer at this time so can't give any confirmation. 1984 One-Ten CSW
2010 XS USW (sold)
Post #861946 16th Oct 2020 5:23pm
Devon-Rover
The bulbs can just be straight swapped out.
380 12V 21/5w for the stop tails
382 12 21w for the indicator and fog
501 5w capless for the front position lights
The junction box is 'Potted' or simply filled with a semi hard gunk to protect the electrics. There is a few posts on here about the right way to remove the NATO plug and wire in a 12N normal trailer plug. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #861961 16th Oct 2020 6:51pm
Ianh
Thanks both, much appreciated.
Post #862002 16th Oct 2020 9:35pm
Ianh
Just bought and collected a penman. Ex reserve stock, looks brand new and never been used, the tyres even have the little bobbles (Vent spews) still on them. Towed perfectly on the 100mile return trip, no sound at all from the hitch. I had to keep checking it was still there !
Now the decision. Keep in nato green, or paint to match defender!
Post #862102 17th Oct 2020 3:14pm
Matt110
Where did it come from? Am also in Essex just wondering if it was local.
Keen to get one myself.
Post #862105 17th Oct 2020 3:23pm
