Home > Maintenance & Modifications > Threaded Bolt Inserts
roche1800
So prior to a complete under seal I have removed mudflats and brackets (plus side runners to be powder coated), the issue I am now faced with is because the bolts were so seized some have snapped and some simply turned what appears to be threaded inserts in the chassis.
They need to be replaced, I was thinking of replacement inserts for RS Components, has anyone had any experience and does anyone have any tips for me?
I have attached a screenshot of the type you knock and not necessarily the exact size.
I intend to fit and put replacement bolts in and tape up so then can be removed to refit mudflats...
Many thanks in advance.
Post #840958 1st Jul 2020 11:20am
Stacey007
When I did mine
I drilled and fitted new rivnuts for the reason you said Smile
https://www.machinemart.co.uk/p/tool-conne...zYEALw_wcB
You basically squeese in a new thread to bolt to, you don't actually need the tool it can be installed with tools you have but easier. My kit was from ebay around £20
Post #840962 1st Jul 2020 11:28am
Paul1275s
United Kingdom 2003 Defender 110 Td5 SW Belize Green
Yup, bought a kit off ebay, has been ace, just make sure you drill the holes for the inserts as close to their diameter as possible. 2003 Defender 110 TD5 SW
2003 Caterham 7
2006 Mini Cooper GP
Post #840974 1st Jul 2020 12:03pm
Notyalc
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Re: Threaded Bolt Inserts
They don’t knock in, that would never hold. You need a tool as said above or some ingenuity and strong arms.
Post #841118 1st Jul 2020 7:47pm
RoddyK05
Scotland 2004 Defender 90 Td5 SW Yellow
You don’t even need to drill out the old insert, a quick dab with a hammer and punch and they pop through. This does however leave a hole slightly bigger than desired for the 6mm rivnut, but it still works. I did mine last week but only had to replace 3 of the six so I think I got lucky. The originals sit flush in the cross member but the replacements have a slight lip on them so they sit a wee bit proud. This can lead to dirty water running down the mudflap which has squeezed its way between the x member and the mudflap bracket. I imagine some dum dum or similar applied before bolting them together would solve that minor irritation. Or a bead of sealer along the seam on the inside?
Post #841147 1st Jul 2020 9:05pm
Oldowner
At one time Land Rover used to put washers between mudflap bracket and outrigger / cross member to stop water being trapped between them and rotting the chassis.
Post #841171 1st Jul 2020 9:39pm
donmacn
Just to say that you can get rivnuts in all sorts of different permutations if you shop around - stainless, hex shaped, smooth or with grooves, with external lips/flanges or without. The ones without - kind of like counter-sinking - sit just about flush with the external surface - though here the hole size is more critical to get them to set.
And if you have a few in different styles and sizes "in stock" then you've often the option of going up a size by drilling a slightly bigger hole.
Apols if you already know this. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #841195 1st Jul 2020 11:17pm
roche1800
Thanks all the info.
I know I have made a mess of at 2 or 3 on front mudflats so going up a size seems a logical option.
Can you just confirm that the front mudflats are round rivnut M8 with 2 each mudflat and the rear are hex rivnut M8 x 3 each mudflap.
Many thanks.
Post #841223 2nd Jul 2020 7:44am
Don't forget this site has all the top tips...
https://www.defender2.net/forum/topic8631.html
Post #841245 2nd Jul 2020 10:11am
ak615
Rear mud flaps are m6
Screwfix do a set of rivnuts lots of different sizes which is quite handy
EASYFIX BRASS MIXED RIVET NUT HANDY PACK 250 PCS (1380J)
Post #841269 2nd Jul 2020 12:13pm
^^ The only snag with that type is that it really isn't easy to find hexagonal drill bits nowadays.
Post #841286 2nd Jul 2020 1:57pm
kmac
United Kingdom 2009 Defender 110 Puma 2.4 USW Santorini Black
Apparently they also work with round holes
Post #841294 2nd Jul 2020 2:21pm
donmacn
.... or you could get busy with a little file?
I say this because there have been a couple of places over the years where I've 'squared off' the holes that used to take self-tappers in order to fit square nylon inserts. This way, it's a better fixing for the screw, and also isolates the metals.
I'm talking about the sort of purple inserts that are used for the floor panel screws; or the smaller white ones used for the screws that attach the lower dash to the bulkhead.
That said, it's much easier to file away at a thin alu. panel than it is at a crossmember! Donald
in the past..
Post #841297 2nd Jul 2020 2:32pm
ak615
Hexagonal sheet metal punches are though
https://www.amazon.co.uk/dp/B0828SFCSB/ref....Eb0RYC7K8
Post #841317 2nd Jul 2020 4:34pm
The hex drill comment was meant as a joke Sad
And the punch in that link is for a circular hole. Laughing
Post #841320 2nd Jul 2020 4:59pm
