|  | Home > My Defender > Defender 90 Toyota V8 swap |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8491      | very smart. you have more patience with wiring them me too Cheers
 James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop | ||
|  19th Jun 2020 8:38am |
| Shroppy Member Since: 25 Feb 2016 Location: Shropshire Posts: 878      | This looks ace!    Can't beat a bit of Japanese engineering, I strongly considered the same engine before I dropped on my RV8 4.6. I'd be interested to see how you went about fitting the puma dash? 1985 127 V8 Build Thread Series 2 109" Series 1 80" | ||
|  19th Jun 2020 10:23am |
| bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027      | Now that is a neat looking engine bay!      2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) | ||
|  19th Jun 2020 10:49am |
| Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 689    | That wiring is a work of art - great work and following with interest. | ||
|  19th Jun 2020 11:17am |
| 90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2309      | Looks a fantastic project | ||
|  19th Jun 2020 7:59pm |
| Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781      | Love this thread!. Rgds.
 Chris | ||
|  19th Jun 2020 8:19pm |
| Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3362      | Nice. Love the attention to detail. WARNING.
 This post may contain sarcasm. | ||
|  19th Jun 2020 8:25pm |
| Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 313      | Thanks for the comment guys.
 I’d say there is probably 200 hours in the engine harness manufacture and probably the same in planning. My profession is in aerospace and motorsport harness design so I kind of know what I’m doing   The puma dash conversion was done as part of the restoration, and a total nightmare! I didn’t get a full puma bulkhead (which would be the easiest way to do it) I only bought the dash and the heater matrix, then fitted that to the tdi bulkhead. It still uses the tdi heater blower which isn’t really capable of pushing the air through all the ducts which means heated seats are a must! 1989 90 4.3 V8 2012 L405 OF 2014 D4 HSE Lux (SOLD) 2015 90 HT (SOLD) @d9o.mf | ||
|  19th Jun 2020 8:47pm |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3788      | Looking forward to hearing this!! | ||
|  20th Jun 2020 6:26pm |
| Bobtailkev Member Since: 17 Mar 2016 Location: Suffolk Posts: 111      | Excellent you are one very talented guy I look forward to the next up date      | ||
|  20th Jun 2020 7:40pm |
| Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5378    |  i did an engine conversion in a rover metro 10 years ago,  from what info is now video wise, i would have had a go at doing the full electrical harness rather than have someone do the engine loom for me, which turned out that i could have done it my self for the sake of switching 6 earths over. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" | ||
|  21st Jun 2020 1:10am |
| Defendermatt Member Since: 15 Sep 2016 Location: Derbyshire Posts: 313      | First job after getting the engine was a deep clean, not that it was particularly dirty but I took the opportunity whilst it was on the stand. I bought the lump as a low mileage, JDM import. Since there was no history I changed the waterpump, timing belt kit, and some gaskets for piece of mind. Timing belt was a pretty easy job, no locking pins. Just turn to set position, remove tensioner and replace belt. I changed all 8 spark plug tube seals as they were all hard and brittle. Treated the cam covers to a nice candy red powder coat too.
   Click image to enlarge   Click image to enlarge   Click image to enlarge I had all the front end stripped off, this made life a lot easier for mocking up with the engine fitted to the box. The gearbox sits on original tdi mounts so no need to worry about prop lengths or swapping seatboxes, just some fresh engine mounts. Both mounts took quite a bit of work to get right, they’re handed to start. Plus the NS has next to no space, unlike the OS which you could fit any size mount you like. I did a few test prints in ABS to confirm fitment then off to be machined. My CNC guy was out of action and I was booked in to have a full exhaust built the week after so I was desperate. I switched the CAD to sheet metal and sent the files off to the laser cutter, along with some machined collars for the bushes to sit in, they all got tigged together.   Click image to enlarge   Click image to enlarge   Click image to enlarge Not sure I’m fully happy with the choice of bush, but I was concerned about them being very hard and feeling every vibration through the car. I might change them to a smaller bush when it’s up and running, we’ll see. I had the td5 tank from the tdi days, great for use with the puma dash as it uses the ROW 300tdi fuel sender. But now comes the added complexity of needing to fit a fuel pump. External pumps such as the Bosch 044 are good for big power but don’t like to suck fuel unless fed from the bottom of the tank, so I decided to go with an in-tank pump. Bring in the DW200, more than adequate of suppling the 3UZs fuel needs. I pinched the mounting idea off a US forum member who was fitting an LS3, he also suggested the Nissan 350z kit as the pre filter was a great fit in the swirl pot.   Click image to enlarge   Click image to enlarge 1989 90 4.3 V8 2012 L405 OF 2014 D4 HSE Lux (SOLD) 2015 90 HT (SOLD) @d9o.mf | ||
|  29th Jun 2020 4:10pm |
| Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2531    | Awesome work!
 Very tempted to get a 'yota V8 into a NAS spec soft top  great summer pub car then lol 2011 Santorini Black USW XS. 2015 Discovery 4.5 Black pack Firenze red XS | ||
|  29th Jun 2020 7:34pm |
| Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3804      | A very unusual engine choice, but congratulations on some magnificent work, especially the loom & re-wiring etc, absolutely exceptional,....looking for more of this story.
 Well done, Pickles. | ||
|  29th Jun 2020 11:44pm |
| Posting Rules
