Home > Technical > is this normal on a Puma engine ?
rossy
Sorry guys, third day of Defender ownership and all the daft questions are comming out !
First daft question
When you rev the engine at standstill it makes a shhh sound as it starts to rev and again when the revs come down to idle - and whenever you turn the engine off it goes 'crunch' (or something does). Is this normal ?
Post #84016 12th Aug 2011 10:31am
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
The shhh sound is probably the turbo, you won't normally hear it when driving.
The crunch when turing off is the EGR valve cleaning cycle.
So both normal
Post #84030 12th Aug 2011 11:31am
Happyoldgit
Re: is this normal on a Puma engine ?
First daft question
No problem with Zaggist questions Wink
You'll also notice that if you press the throttle a little while in neutral the revs will rise as expected but then drop back a little. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #84034 12th Aug 2011 12:09pm
Naks
it's not supposed to go 'crunch' - it's supposed to go 'chukka-chukka' 5 times or so:  --
Post #84039 12th Aug 2011 12:26pm
rossy
no its definately a heavy metalic crunch - for a split second
Post #84043 12th Aug 2011 12:49pm
Naks
that's not right - it could be a stuck EGR valve. have it seen to asap! --
Post #84044 12th Aug 2011 12:49pm
Honker
 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Rossy, my one (500 miles old) shudders when I turn it off and then you can just here a metallic swish , swish , swish which I assume is the EGR clean.
There is no heavy metallic noise though.........wel not yet anyway.
Stu
Post #84088 12th Aug 2011 4:50pm
rossy
just went for a spin and the egr has started doing its cycle - the 5 chukkas when switching off - it never did that until today - the car only has 300 miles on it so maybe things are freeing up since sitting around for the 2 months since it was built.
The crunch has become more of a shudder and its from the transmission area. I have noticed that the Gbox and Tbox levers wobble about a bit in unison when driving as if the whole transmission is on flexible mountings. Don't know if thats supposed to happen but the gearchange is nigh on perfect with no clonks or shunts - does anyone else have wobbly levers ?
Post #84089 12th Aug 2011 5:02pm
rossy
sorry Honker you must have posted same time ish as me didn't see it until I submitted and you are right - its more of a shudder - does your gear levers move about on the road as if both 'boxes are moving about ?
Post #84090 12th Aug 2011 5:15pm
Honker
Well they move around a bit but no more than I'd expect, more than a diesel car but not something I'd say is an issue. My gearbox has a chunky change but again nothing more than I'd expect.
The shudder is different to a normal car and feels as if it's just settling on it's mounts, I've just assumed that's normal!! Smile
Stu
Post #84119 12th Aug 2011 8:26pm
rossy
I had a good look underneath and I found the answer !
The transmission is attached to the chassis by two mountings - Gbox to the left side and Tbox to the right. Each mounting features a big fat rubber bush which explains the movement on rough roads. Embarassed
But you know how it is with a new car. Every squeak is a potential disaster until you get to know its ways
Post #84150 12th Aug 2011 10:51pm
Small Clanger
Too true. Check out www.hamsterfanaticforum.co.uk
Post #84224 13th Aug 2011 6:21pm
rossy
Laughing
Post #84276 13th Aug 2011 10:54pm
Small Clanger
Apologies Smile
I know what you mean though. My 90HT's about seven weeks old now and I've done about 1600 miles in it. At first I thought the gearbox was knackered so I asked a few Land Rover driving mates to have a go. "it's fine" they tell me.
I'd traded in a 59 plate LWB Wrangler for the 90, not exactly cutting edge technology in itself but very reliable and comfortable over the 18000 miles I'd covered in it. Getting into and driving the 90 felt like stepping back 20 years. It's a basic, agricultural, noisy and characterful vehicle and I'm very pleased with it so far.
Reading some of the stuff on here can certainly (and probably un-necessarily) put the wind up the first-time Land Rover owner, I guess the thing to remember is that you're only reading about the bad ones not the thousands of good, reliable, hard working ones out there.
Having said that, I've just booked mine in with a local garage (not the L/R dealer but an independant recommended by other Land Rover drivers) for a general check of fluids/levels/nipples and the oil and filter changing. Just to be on the safe side. Very Happy
Post #84325 14th Aug 2011 11:14am
Zagato
Just checked my levels again - spot on and propshafts have greased nipples Thumbs Up I won't be taking mine to the dealer for it's first service but Gigglepin Thumbs Up Will ask them to do other checks when the time comes also Thumbs Up
Post #84357 14th Aug 2011 4:19pm
