Home > Maintenance & Modifications > Bulkhead mounted spotlights |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 732 |
Has anyone had any experience on these spotlight brackets which fix onto the bulkhead? I can't see how they fix onto the bulkhead as it says no drilling or cutting required?
https://www.firstfour.co.uk/product/bulkhe...nder-pair/ Seems like a good mounting option while still allowing the vent flaps and bonnet to be opened. Many thanks BORG - Bucks & Oxon 4x4 Response Group |
27th Jun 2020 9:55pm |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
No experience but they bolt under the windscreen brackets. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
27th Jun 2020 9:59pm |
The intention was to fit some amber flashing lights on there for 4x4 response duties. I would prefer not to drill the roof.
I have an a bar for driving lights.
Thanks BORG - Bucks & Oxon 4x4 Response Group |
27th Jun 2020 10:10pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6051 |
Years back on my first 90, I had the standard "lucas"/LR reversing light (the round type with the grille and handle on the top), I had a pair of these, one each side of the screen, "coz I thought it looked kool"....
Funnily enough I was looking through some old pictures today and saw it, and immediately thought how cr@p it actually looked and remembered how utterly useless they were. As said above, they illuminated my wings and bonnet perfectly. not much else. Bolted under the screen hinge brackets. |
27th Jun 2020 10:13pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17003 |
It is, however, the location of the sidelights on one of my 80"s (an idea bizarrely copied by the exceptionally hideous Fiat Multipla).
27th Jun 2020 11:12pm |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 760 |
I have had floodlamps located in a similar position on my previous LR's (S111 SWB V8 & 101FC) and found it to be an excellent location.
With roof mounted lights I found that they reflect off the bonnet. When off-roading, bumper mounted lights tend to get covered in muck. Bulkhead mounted lights were at the perfect height to give good illumination but also kept reasonably clean, also they were perfectly positioned to provide excellent illumination under the bonnet if required (on the S111 at least). Click image to enlarge ONE LIFE, GET IT! |
28th Jun 2020 12:49am |
stanley Member Since: 18 Sep 2009 Location: Dorset /hampshire Posts: 1029 |
RNLI have something similar
Click image to enlarge |
28th Jun 2020 6:46am |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 513 |
For off road or work light use they are actually in the perfect position as it allows you to offset the beam slightly to illuminate the sides of tracks and obstacles at the side of the vehicle. 99% of tractors also have worklights in a similar position - just below the windscreen as it also prevents glare off the bonnet. roof mounted work lights can create an issue with this
28th Jun 2020 8:15am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2107 |
They still look naff though !
Mo The Land Rover 90 - Many are called, few are chosen. |
28th Jun 2020 9:27am |
