![]() | Home > Technical > Central Locking problem |
| AMBxx Member Since: 24 Jul 2016 Location: York Posts: 1073
The central locking has stopped working on one door - driver's side, 2nd row.
I assume it's a broken wire in the rubber tube that leads to the door. Before I start ripping it apart, are there any other likely locations for the problem? |
Thanks - I'm busy this weekend, but will take a look by the end of the month.
| Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 285
I have had issues with mine as the doors in the back are not used much and needed the old grease cleaning off then re-lubing. Of course in this case you could hear the solenoid trying to work.
When the front failed it was the wire in the door as it went through the little black tube and no solenoid sound. 2008 Defender 110 XS CSW Volvo XC40 Recharge Triumph T120 BMW R1300GS G0UBX |
| DG123 Member Since: 29 Aug 2015 Location: North West Posts: 143
I had same problem. Thought it was the wires as they’ve gone before but on inspection they were OK
I popped off the door cards and sprayed all linkages with white grease. As Swallock noted, back doors were the most seized cos of lack of use. Been fine since. 2012 110 XS SW Orkney Grey 2003 D2 Td5 Black [SOLD] |
I can't believe it's taken a whole year for me to get round to fixing this!
Could this be the problem? Click image to enlarge |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Er, yes. Darren
| ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1777
you can get a loom upgrade kit I think
| All times are GMT |
