![]() | Home > Maintenance & Modifications > Revert LED Headlights? |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
I believe they are all the same H4 plug so should be a simple swap, add stainless lamp bezels and screws at the same time
![]() ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
Don’t blame you, I like LED but not those Halo ones.
As mentioned above, they should be H4. They might, however, have tapped feeds from the sidelights above hence the halo ring. If so just unplug if it has connectors, if hard wired just isolate the ends of those so they are safe and can be tucked away. Only take out the headlight retainer screws and don’t touch the alignment screws. You’ll see the difference. After it’s done and the above SS bezels and screws are a good idea you might want to get them aligned at an MOT station. (Costs peanuts) Whilst the beam adjustment wouldn’t be altered by you, the change will likely alter the beam pattern all the same. 👍🏻 ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
BlueIn2Red Member Since: 04 Aug 2019 Location: Tring Posts: 11 ![]() ![]() ![]() |
Thanks a lot guys, I went ahead with this and all went fine as you suggested. The wiring was indeed wired in with the sidelights/indicators, but I was able to just unplug this (leaving part of the LED wiring in place, which at the time meant I thought it wouldn't work properly), and everything worked. I'm much happier with the look of the new headlights, far more fitting with the rest of the vehicle in my opinion.
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2542 ![]() ![]() ![]() |
I'm not a fan of halo headlights, in fact SWMBO always comments on Defenders with halo's when they are coming towards us. I'll not quote her exact words.
Glad your conversion went ahead ok. Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
