Home > Maintenance & Modifications > For when a battery needs changing.
spudfan
Ireland
Anyone used this or something similar? Is it really necessary for something like the Puma for a battery change?
http://www.tayna.co.uk/Gunson-77065-Memory...P8304.html 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #83826 10th Aug 2011 11:02pm
noworries4x4
Absolutly no need with a Puma all you need to do is put a radio code back in no trouble with imobiliser, if you have back up alarm you have to disconnect within 20 sec of turning ignition off with the passenger door open as you would have anyway If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle
Weekends MY 12 L322 4.4 TDV8 Vogue
No Worries 4X4
Post #83827 10th Aug 2011 11:08pm
leeds
Why not get something like a cTek 7000?
That has a supply mode amongst it's functions. Also has a few other functions whereas the device you link to appears to be just a set of 'jump leads' I.e. Connecting a slave battery to vehicle electrics.
Oooops am I being biased? Razz Rolling with laughter
Brendan
Post #83828 10th Aug 2011 11:14pm
My radio seems to retain its code for about 10 minutes after disconnecting the battery.
Post #83867 11th Aug 2011 10:34am
K9F
My old head unit did too, but probably only three or four minutes! Seems that there is a delay in the unit code clearing so if you 'whip it out' and 'whip it in' there may be no need to re-enter the code.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #83891 11th Aug 2011 1:35pm
