![]() | Home > Td5 > Not charging :-( |
Sicastle71 Member Since: 21 Aug 2019 Location: West Lancs Posts: 128 ![]() ![]() ![]() |
Sounds like alternator I’m afraid. If it’s only 11.7v switched on sounds like rectifier circuit has blown a diode or two check with engine running and ancillary son should be an output of about 14v sorry 😐
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17946 ![]() ![]() ![]() |
Did you jetwash the engine compartment?
Otherwise classic symptoms of a failed alternator, usually in my experience on a TD5 because the vacuum pump has filled the alternator with oily gunk. If so, my advice is bite the bullet and fit a.new OE quality alternator and pump |
benniferj Member Since: 20 Oct 2016 Location: Basingstoke Posts: 361 ![]() ![]() ![]() |
Worth checking that the multipoint loom that plugs in the back of it is still plugged in and not full of crap
Did you jet wash the alt at point blank range? Insta: @thebenjordan4x4 |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6030 ![]() ![]() ![]() |
No jet washing of engine bay took place. Just a unahppy coincidence I think.
![]() I did check the multiplug and still attached. 11.7v at the back of the alty with engine running. Also checked the brake lights worked - and they do. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
No jetwashing the engine bay., There is oil on the alty and on some pipes below. Another Denso to order, last one was about 2-3 years ago 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
I would take the alternator apart and have a look. Could be as simple as a stuck Carbon brush (Is that correct englisch?)
It could be that the 11.7 Volt is the battery with the fuel pump running etc. I think the alternator is doing nothing. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5998 ![]() ![]() |
Yes correct English Roel. Well done
Sadly it seems to be really difficult to find spare parts (like slip rings and brushes) for the TD5 alternator.
it does appear difficult to find parts
![]() The alternator is out. Two awkward bits, removing the multipin plug from the rear and the bottom oil drain pipe. On the plus side, I found the original reciept for the alternator dated late 2018, so just under warranty(i hope). I have sent an email to the company I got the alternator from, so lets see what they have to say. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
https://www.buycarparts.co.uk/oen/err6999
HC CARGO and part number https://ecom.eraspares.com/ec/TabelloneRic...1002132530 |
Cheers DS. I still have the original one that was replaced by this one that has failed!l, so might run that one down to the autosparks place to see if they can ID the failed parts. 1999 Defender TD5 110
Faulty one going back to the supplier for testing. 1999 Defender TD5 110
Alternator picked up and off to be tested. 1999 Defender TD5 110
Alternator sent back, confirmed as faulty and refund given. 1999 Defender TD5 110
