|  | Home > Puma (Tdci) > 2.4 oil consumption |
| bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027      | Thats a lot of oil!
 Mine doesn't use any, nothing at all i have never had to top up (unless after service once its settled. i presume you have checked for leaks underneath? and around the oil filter, sump and plug 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) | ||
|  20th Jun 2020 5:11pm |
| Shepherd Member Since: 21 Apr 2014 Location: Devon Posts: 22      | Do a bit of a search on injector seals.
 They sit on a copper washer that is prone to causing a few issues | ||
|  20th Jun 2020 6:12pm |
| Don Member Since: 20 Oct 2013 Location: Stockholm Posts: 3    | Great, many thanks!
 I removed the cover and found as shown on the picture. Doesn´t look strange to me...   Click image to enlarge | ||
|  21st Jun 2020 12:05pm |
| Shepherd Member Since: 21 Apr 2014 Location: Devon Posts: 22      | It looks wet around the injectors? Esp 3?
 A diagnosis is obv difficult on here but the parts to replace the seals are cheap so i would be doing them next if it was mine. It’s been a couple of years since I did one but if I remember correctly it’s not a bad job to do if you go steady. You don’t need to replace the fuel lines. Just the copper washers plus new stretch bolts and I seem to remember replacing some small rubber o rings on a few pipes. I used a small file/seating type tool to clean up where the washers sit. I will put a bit more info up when I got a bit more time Hope you get it sorted | ||
|  21st Jun 2020 10:38pm |
| Don Member Since: 20 Oct 2013 Location: Stockholm Posts: 3    | Thanks. It is for sure wet there but can it explain the excessive oil consumption? | ||
|  22nd Jun 2020 12:00pm |
| Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696    | Mine has 70K miles on it and uses none between changes.
 The injector seals leaking aren't causing that much loss - in fact I believe they are leaking combustion product not oil as such. With zero frame of reference with your particular vehicle does it smoke at all? Smoke on overrun would suggest valve guide oil seals, smoke under load could be oil being burnt, providing it's the right colour (blue-ish I believe?). I don't believe excessive oil consumption is common on these engines though, so worth investigating. Others may have more / better ideas. | ||
|  22nd Jun 2020 2:57pm |
| Shepherd Member Since: 21 Apr 2014 Location: Devon Posts: 22      | |||
|  22nd Jun 2020 9:55pm |
| Argee Member Since: 13 Nov 2017 Location: Suffolk Posts: 71      | Mine turned out to be a snafu'd turbo....
 Oil leaking from inter-cooler pipework junctions and also getting past the turbo seals, exiting as smoke via the zorst. | ||
|  23rd Jun 2020 12:28pm |
| Posting Rules
