Home > Maintenance & Modifications > Wiper fault
LANDROVER
Wiper fault
Laughing My Land Rovers loves to give me something to do each week Rolling with laughter
The wipers have stopped working, which is great with all the rain we've been having.
I have pulled the motor assembly out and with it disconnected it does not blow the fuse.
When plugged in as soon as you move stalk the fuse snaps with a lovely flash.
The wipers feel quite stiff to move even after spraying pivot point....how much resistance is normal?
Should I just swap unit complete or try stop switch first? Motor looks fine inside and doesn't smell burnt or overloaded?
Post #838394 19th Jun 2020 11:26pm
It's the resistance that's blowing the fuse. Your problem will likely be worn or seized spindle boxes, I suspect. Darren
Post #838416 20th Jun 2020 8:00am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
As above but have a looo at the stalk connections also as the stalks are fragile that is before you start stripping dash to get at the wheel boxes. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #838431 20th Jun 2020 9:02am
