![]() | Home > Puma (Tdci) > Cant get MudUK reverse LED to work |
| Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3671
Have you swapped the polarity of the cables?
| jbullis Member Since: 28 Apr 2013 Location: Jonesborough, TN Posts: 24
I'll try popping out the pins and swap the cable to see if it works. I would hate to think two were wired wrong?
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6735
Worth trying this, as your reverse light plug (on the vehicle harness) may be wired back to front. Or the socket on the lamp may be wired in the wrong pins. Or post some pics of which wire is where on the plug and on the socket and I'll check what they should be. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Click image to enlarge Thanks for the quick reply’s. I swapped the wires and it lit right up. |
| Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 781
LED's are polarity sensitive. Rgds.
Chris |
| discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2544
Had a similar problem on some plough lights I recently bought for my tractor. Someone on the Chinese production line couldn't tell the difference between a red wire and a black wire or decided to swap them around for sheer devilment. Defender 90XS SW
| All times are GMT |
